First Thread - AOD replacement
  • Thread starter Thread starter retownsendjr
  • Start date Start date Jan 17, 2011
R
retownsendjr
Catlett, VA
Jan 17, 2011
  • Jan 17, 2011
Hello from Northern Virginia
Hopefully this question will not cause lots of laughing and finger-pointing, but here goes:
I hired a shop to replace the AOD transmission in my 89 LX Convertible. I provided the used transmission, which I bought from a reliable source.
The guy from the tranny shop called today and told me that the convertible and the hardtops had different trannies, and that the one I bought is for a hardtop, and that I need to have the driveshaft shortened 1/2 inch for and extra $100.
Does this sound correct to anybody? Is it BS?
Thanks,
Rich
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Jan 17, 2011
  • Jan 17, 2011
Not saying you didn't supply him with the wrong transmission, but he is totally off base about Mustang tranny's. A Mustang AOD is a Mustang AOD.
wht87gt
127
Oxford, MA
Jan 17, 2011
  • Jan 17, 2011
That's BS. I think he's either a complete moron or he's trying to scam you out of your hard earned money. Either way you need to find a new shop to do your work.
RYC CUKR
1,437
Orlando
Jan 22, 2011
  • Jan 22, 2011
He is offbase about transmissions differing between the hardtop and the convertible.
However there is a difference between some of the AODs. AODs that were installed in some of the Lincolns have a longer tailshaft which will necessitate a shorter driveshaft. I can't remember if the ones from the trucks are also longer but I know that the Lincoln AODs are longer. When I swapped mine I made sure to measure. I ended up with one from a Mercury Grand Marquis in my 93.
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Jan 22, 2011
  • Jan 22, 2011
Did he say if that Hard top model of AOD was for a hatchback or coupe? lol What a moron for sure!
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jan 22, 2011
  • Jan 22, 2011
Mustang AOD all the same....but the AOD in other ford cars are slightly longer. What did you get the transmission out of?
G
Gen414
47
  • Jan 23, 2011
Hey guys, new to the site, and Im not meaning to hijack, but my question DOES pertain to the OP question about the AOD (sort of)
I am doing a swap for a customer right now...car is a '93 GT, and as delivered had a C4 in it (yes, I know, not original to the car) and customer wants an AOD put in. It has the AOD shifter still in it, but IS missing TV cable.
Now, customer supplied AOD and converter and everything is fresh/rebuilt from some shop in Florida.
So, have few questions:
Does Ford still have the TV cable for sale? Or is it junkyad time? 2nd, how do I go about routing/adjusting it properly to make sure I don't burn up tranny.
Other question pertains to length..as I was installing AOD in car, got it bolted up, and went to put in driveshaft. Car is on 2 post lift, so all of the weight was OFF the rear suspension, so just dead weight, and I had to shove driveshaft as far as I could get it to go inside tranny and was JUST able to slide it up over pinion flange.
So, is it possible that he brought in a Grand Marquis AOD that you guys are saying is longer than a Fox Body AOD?
Again, not meaning to hijack, just felt OP could benefit as well as myself from info shared here. Thanks
Does anyone have overall case length dimensions for Fox AOD/Grand Marquis etc..AOD?
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jan 23, 2011
  • Jan 23, 2011
I wanna say the passenger car AOD is 1" longer than the mustang AOD.
As for tv cable....junkyard time.
G
Gen414
47
  • Jan 23, 2011
OK, thank ya brother.
That would make sense then...Im betting that this a passenger car AOD then. I just don't see this drvieshaft working as it it is too long. Once I load the suspension up, gonna shove that drivehsaft furhter in, and is gonna be bottomed out. Looks like it's time to have DS shortened.
TV cable...any F.I. 5.0/AOD setup will work? passenger car/Fox body/cougar/Tbird??? Or no?
Thanks again
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
D
91 GT Convertible AOD Upgrades
  • DHatton
  • Jun 7, 2022
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2022
LAFF
L
Drivetrain AOD Edge Converter Order Form Specs
  • 5.0specialist
  • Dec 19, 2020
Fox 5.0 Mustang Tech Dec 21, 2020
5.0specialist
Engine New to Mustangs, guidance needed on fault codes 47 & 45
  • sUdz6.0pwrstk
  • Sep 30, 2021
4K
Fox 5.0 Mustang Tech Oct 23, 2021
General karthief
Fox AOD Overdrive to 3rd Hard Downshift
  • Motorsport71
  • Mar 18, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2021
junkyardwarrior
J
