Hello. I'm Jon or Suds. First post here at Stangnet and completely new to the Foxbodys.
Quick back ground:
We purchased a 1989 hatch foxbody gt AOD transmission apparently converted from a 4cyl LX. A 5.0 was installed and I believe it's from a 91 model. Honestly they did an awesome job imo. After a few things we've done so far, car runs extremely smooth with a few hiccups.
Before I get to the things we've done I'll present the problem.
Using an Innova scan tool and after a 5 or 6 mile run we've have fault code 5, 47,4, and 45 (in that order) at KOER. Also the scanner did NOT show the number of cylinders.
While we've used the new scan tool multiple times to troubleshoot other issues it has always read the cylinders.
I've scanned the net on the codes 47 and 45, we haven't found any help on these. KOEO codes we have is o85 and c96.
Now for the progress so far:
Brand new fuel related parts from CJ Pony
Tank
Fuel pump
Sender
Filler neck
Fuel filter twice
Fuel rail flushed
Fuel pressure regulator
Injectors in the car were a, I guess you'd call it a single spray plunger type. We bought a set of rebuilt 4 hole spray pattern from a dude in Cali.
Fuel pressure holds 30+ at idle, up to 40 on acceleration.
Compression is 130+
Advanced Auto distributor with tfi.
New plugs
Ford Racing plug wires
Ignition coil
New starter
Battery cables, positive cable to the starter and negative cable.
Battery
Fuel pump relay (under driver seat)
Ecc relay
TPS
Coolant temp sensor not the one for the gauge cluster
Air charge Temp sensor
Water pump
Thermostat and housing
Intake gasket
Timing is set to 10* with out spout connector
The latest major problem we had possibly solved was the car randomly jerking like the rear end was about to fall out and losing all power when giving it fuel while cruising. Code 18 was popping up every once in awhile that's why we replaced alot of the ignition parts. Distributor and 2 TFIs not to mention tracing wires until I was about to pull the trigger on a new harness. Turned out to be a wire loom that went to the transmission sitting on the exhaust pipe.
I'm not sure what the sensor is that the harness went to, believe it was a neutral safety switch. I only see 2 places a harness runs to, one in the front of the transmission near the bellhousing and the speed sensor next to the cable. The wires weren't visually damaged but the loom conduit was melted a bit. I think the heat from the exhaust pipe was causing some interference some how. Rerouted the loom and cable, no more violent bucks or jerks.
Another note, there is not a charcoal canister, holes in the heads for smog pipes are plugged, both vacuum lines are plugged. Bypass pulley is installed. Connector for the pump is just lying there. Noticed the tail pipe branch is plugged aswell.
This car is pretty much for my son who has zero interest in anything other than cars and video games. Fishing, camping, boating, and hiking too but those aren't things we can do after a hard days work or school. Complete restore on this ride if we have too.
My apologies for a long post, feel free to skip around, I won't mind repeating things if questions are asked. Cheers.
Quick back ground:
Tank
Fuel pump
Sender
Filler neck
Fuel filter twice
Fuel rail flushed
Compression is 130+
New plugs
Ignition coil
New starter
Battery
Ecc relay
TPS
Water pump
Intake gasket
