First time at the track with my '06
  • Thread starter Thread starter kooldawg6
  • Start date Start date Apr 22, 2007
1 of 2 Next Last
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Apr 22, 2007
  • Apr 22, 2007
Went to Mason Dixon Dragway in Boonsboro, MD(just outside Hagerstown).
With my mods and seeing what others were running on StangNet, I was hoping to see some 13.30s...I got'em and VERY consistant as well!!! 4 runs and they averaged 13.364 @ 104.06. My best was 13.345 and 104.34. The 60' times were close as well(all 4 runs at 33 psi with factory 18s). That average was 2.042 with a best of 2.032. In the 1/8 mile my averages were 8.613 and 82.62. My best there was 8.601 and 82.77. I want to try and keep my performance mods fairly simple and get into the 12s. I believe I could see that with a driveshaft replacement, UDPs and sticky tires.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Apr 22, 2007
  • Apr 22, 2007
Awesome numbers.
Jenns01TA
37
Apr 22, 2007
  • Apr 22, 2007
Nice R/T for a newbie bracket run The AOD did its job from there and the mods earned you an excellent time.
PoopDawg - Just replay the video after it stops at the mid-point and it will cycle through his entire run.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Apr 23, 2007
  • Apr 23, 2007
AOD? What 06 GT does he have? I hope he's got a 5R55S in there.... See what digusting GMs do to you?
kooldawg6
Aug 31, 2006
1,679
Central VA
Apr 23, 2007
  • Apr 23, 2007
gashog
139
Fresno, CA
Apr 23, 2007
  • Apr 23, 2007
Good run
Those 4.10s look like they are really working!
Jenns01TA
37
Apr 23, 2007
  • Apr 23, 2007
Yeah-Yeah Poop. GM has created brain rot. Forgot that the inherently weaker 5R55S is not a true OD like the 4R70W.
You may conduct your BS insults to me via PM, Sport.
kooldawg6
Aug 31, 2006
1,679
Central VA
Apr 23, 2007
  • Apr 23, 2007
gashog said:
Good run
Thanks gashog! I did notice I have some wheel spin. The track seemed good for my auto. I did launch the last 2 times with it brake torqued up near 2000RPM. It would grab 2nd gear everytime, then into 3rd and 4th the car would kick hard(SOTP feel was awesome).
kooldawg6
Aug 31, 2006
1,679
Central VA
Apr 23, 2007
  • Apr 23, 2007
One thing I forgot to metion during the original post was my RPMs as I crossed the 1/4 mile stripe. It was 5400 RPM. That was having my shift points set a 6800, 27.3" tire, and 4.10s. I never did any passes this go around with the limit set at 6100-6200 RPM. Next time I will switch it up as I will have some better 60' times as well both by lower PSI in the street tires and DRs. That should get me much closer to the 13.0 barrier
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Apr 23, 2007
#10
  • Apr 23, 2007
  • #10
Why would I do it via PM? Then no one else can publicly agree with me.
And you're telling me a 5R55S is weaker then an AOD, correct? I really don't see many stock ones living being a 300 HP car very long.
Jenns01TA
37
Apr 23, 2007
#11
  • Apr 23, 2007
  • #11
Check your PM box PoopDawg. You have a love note from me and with it came two infraction points. Keep it up and you will earn a mini-vacation.
AOD is an accepted generalized automotive acronym for an automatic with overdrive you know it as do others. Now move on. As for my comment on the tranny - do the research and bring it to the table.
You can bag on my car all you want, but in this house you will abide by rules and one of those rules is "DO NOT CONFRONT STAFF IN OPEN FORUM". You just did that and therefore you earn the attention you are looking for.
Second house rule - don't insult or insight members. Fair warning and I say this right now - if you have contention with me bring it to PM and the mods of record. Keep it up and I will show you to the door.
Am I clear?
07gtfolife
125
#12
  • Apr 23, 2007
  • #12
Your reaction time is amazing
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Apr 23, 2007
#13
  • Apr 23, 2007
  • #13
Am I clear?
Clear? Not at all. But I best not state my case in an open forum or else, right? But it is perfectly OK for you to state your case THEN say I better not state mine. Seems fair to me! I sent you a PM
kooldawg6
Aug 31, 2006
1,679
Central VA
Apr 24, 2007
#14
  • Apr 24, 2007
  • #14
Thanks! I did have 2 red lights as well. Reaction time is pretty easy to do in the automatic. I use my left foot on the brake and the right is on the gas and as soon as I see the last amber bulb light I gun it.
BREDn07
54
Fresno, Ca
Apr 24, 2007
#15
  • Apr 24, 2007
  • #15
kooldawg...
your horse slingshot out the hole like a AWD car!!!! that was nice to see...
i got 3.55 pose (factory) i'm switching to 4.10's for sure now!!!
you and i almost have the same mods....the only thing i added is shorty headers haven't done a new tune since i put the headers on!!! plus i got a 5-speed, so hopefully i can come close to your numbers! good job...
ScottM
219
Little Rock, AR
Apr 25, 2007
#16
  • Apr 25, 2007
  • #16
Very nice times! My track is only 1000' long rather than a 1/4 mile and my best so far is 11.21, I see your 1000' time was 11.17. Those numbers seem spot on. At the time, my only mods were CAI and tune, O/R H, Stingers, and lowering springs (I know, they don't help).
Get that 60' down to a 1.8 or so and you could very well see 13.0-1ish!
C
chubhunter
63
heartland
Apr 25, 2007
#17
  • Apr 25, 2007
  • #17
ScottM,
Do you drive a manual? If so I was wondering at what rpm you try and launch. I am thinking of going to the track for the very first time and am clueless as to how to get the best launch.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Apr 25, 2007
#18
  • Apr 25, 2007
  • #18
chubhunter said:
ScottM,
http://forums.stangnet.com/showthread.php?t=693015 should get you started....
C
chubhunter
63
heartland
Apr 25, 2007
#19
  • Apr 25, 2007
  • #19
Checked it out. Thanks again bigcat.
A
ALLOY2007GT
99
#20
  • Apr 25, 2007
  • #20
kooldawg,
you are lucky that other dude couldn't drive worth beans or you would have lost , lol. He trapped 2.5 mph higher than you hahaha. must drive a manual, an rt of .6 and a 2.1 60". what a tool.
1 of 2 Next Last
My First Time Down A Track
  • Detroiit
  • Jul 13, 2014
  • Video and Media
2K
Video and Media May 5, 2018
gtsn95
Went to the track tonight; Got some problems/questions
  • sneaky98gt
  • Jun 18, 2009
  • 2 3
4K
1996 - 2004 SN95 Mustang -General/Talk- Oct 9, 2009
sneaky98gt
  • Sticky
The 4.6 Track Times Thread
  • COramprat
  • Jan 28, 2009
  • 5 6 7
75K
1996 - 2004 SN95 Mustang -General/Talk- Nov 2, 2019
Slider
M
93 LX - 460 swap
  • MrLight460
  • Dec 18, 2008
2K
Fox 5.0 Mustang Tech Dec 18, 2008
MrLight460
M
K
First time at the track w/ my new stang :)
  • Kodiakkid311
  • Dec 18, 2006
2005 - 2014 S-197 Mustang -General/Talk- Jan 13, 2007
NewbStang
N
