First time starting up!!
  • Thread starter Thread starter A67StangMaster
  • Start date Start date Jul 13, 2006
A67StangMaster
401
San Jose CA
Jul 13, 2006
  • Jul 13, 2006
ok guy I just put everything Back into the car. Yea I am so happie I got this thing back together Hopefully its runs with no problems which i dought.
But my question is what should i do before hand? I just got the motor in and nothing has been done to it its been sitting in my garage for atleast 1 year.
Anything I sould do or check before I try to start her up?
(fyi) I had a stock rebuild on her.
67Dylan
259
Phoenix, AZ
Jul 13, 2006
  • Jul 13, 2006
How about priming the motor? Making sure the fluids are all filled; radiator for example. Timing light. Crossed fingers. Good luck and let us know how she does.
G
grego37
576
Fresno CA
Jul 13, 2006
  • Jul 13, 2006
Dead time it so its close.
prime the oil system
use some starting fluid to ensure a quick fire-up.
Are you breaking in a new cam/lifters?
A67StangMaster
401
San Jose CA
Jul 13, 2006
  • Jul 13, 2006
ok yes i have a new cam and lifters everything is new on the motor except for the heads.
how would i prime the oil? what would i need to do?
washMO66
1,000
Washington, MO
Jul 13, 2006
  • Jul 13, 2006
I pulled my distributor and stuck in a priming rod and turned it with a drill to get everything oiled prior to firing. You can get them at most autoparts stores....
G
grego37
576
Fresno CA
Jul 13, 2006
  • Jul 13, 2006
do you know how to break in a cam properly? and with which oil and which additives for break in?
if you're not sure , contact your cam company.
The first 15 min of a motors life are the most important, and if you dont break in the cam properly, you'll have to start over and install a new cam and lifters.
A67StangMaster
401
San Jose CA
Jul 13, 2006
  • Jul 13, 2006
ok well this cam everyone would know its what i upgraded long time ago
edel-2122 and edel-2121
its a little bigger then the stock on but it sould work good with the set up i have.
is there any other ways of primeing the engine?
G
grego37
576
Fresno CA
Jul 14, 2006
  • Jul 14, 2006
removing the distributer and using a priming tool with a hand drill is the only way I know to prime an engine.
If you go to start a fresh engine without priming the system, there will be no oil for a few seconds where its needed, and you can hurt vital components.
jtfairlane
468
  • Jul 14, 2006
Check out http://www.paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=62610
for an example of what an Oil Pump Primer is. They are CHEAP, and offer the best insurance that everything is coated in oil before you fire your new motor up. Take the 5 minutes to do this, so you don't ruin $5k. Always time to do it twice, but never time to do it right.....
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jul 14, 2006
#10
  • Jul 14, 2006
  • #10
If you have power steering, make sure you have PS fluid filled or you may damage the PS pump
67Dylan
259
Phoenix, AZ
Jul 14, 2006
#11
  • Jul 14, 2006
  • #11
for an example of what an Oil Pump Primer is. They are CHEAP.....
That is inexpensive! I've used a socket/driver w/tape on it before, but had a friend use this 'technique' and drop the socket. We had fun lifting the motor, dropping the pan, and locating the socket . Ever since then I've used the cheap tool.
A67StangMaster
401
San Jose CA
Jul 14, 2006
#12
  • Jul 14, 2006
  • #12
Ok I will head to the part store and get ones of those.
ok thanks guys for the help.
garner67
68
SF Bay area
Jul 14, 2006
#13
  • Jul 14, 2006
  • #13
Dumb question...
Using an oil pump primer in the distributor shaft on a 351w, which way should the drill rotate to prime the engine.... clockwise or counter-clockwise? Or does rotation direction not matter?
thehueypilot
1,084
Medina,Tennessee
Jul 14, 2006
#14
  • Jul 14, 2006
  • #14
garner67 said:
Dumb question...
Counter clock wise and it does matter. The drill motor must be run backwards which is really hard on them.
thehueypilot
1,084
Medina,Tennessee
Jul 14, 2006
#15
  • Jul 14, 2006
  • #15
I have removed all the spark plugs (leave the distributor in but unhook the positive wire going to it and plug the fuel line) and charged the battery and left the charger on it and let the starter motor crank it over to build pressure. You can sit and watch the oil pressure gage build as you crank the car. Don't turn the starter motor longer than a minute otherwise it will get very hot. This puts zero pressure on all parts and allows the oil to flow into all bearings and pumps up the lifters. If you assembled the engine with assemble lube or lots of oil recently this will work. If you put the engine together with oil a long time ago you should prime it like they mentioned in the above posts. Good Luck!
joesgt281
163
Katy, TX
Jul 15, 2006
#16
  • Jul 15, 2006
  • #16
I'm sure this has been covered elsewhere before, but seems relevant for this thread as well.....what about proper oil for initial engine break in?
I've heard people say not to use synthetic, to drain it after the first few minutes of operation, etc.
Any opinions out there? I hope to be cranking mine soon too.
D
D.Hearne
11,730
south louisiana
Jul 15, 2006
#17
  • Jul 15, 2006
  • #17
With an AC drill motor or even a DC for that matter, it doesn't matter which way it turns, the output is the same there is no forward or reverse when it comes to which rotation is better. Same thing with Diesel electric locomotives, they run at maximum output in either direction. All electric motors are this way.
D
D.Hearne
11,730
south louisiana
Jul 15, 2006
#18
  • Jul 15, 2006
  • #18
If it's been a year since you put it together, you really need to pull the intake and the lifters and see if there's any cam prelube left on the lobes. If there's not, you can dab a bit on the lifter bottoms and put them back in the holes. It's best not to put too much though. And do not put any on the sides of the lifter. Motor oil only there. The thing that's critical at startup is for the cam lobe to grip the lifter bottom at fireup, to set the lifter, into motion, spinning in it's bore. No spin and you're guaranteed to wipe the lobe. You don't want thick cam lube on the lifter sides making it more difficult for the lifter to spin. Also check each lifter to see if it rotates freely when you drop them in the bore. Use a diesel spec oil or a non detergent oil for cam break-in. Do NOT use synthetic oil what so ever. After the break-in run of 20 to 30 minutes, if its' sucessful, then kill it and change the oil and filter. And use fresh oil, probably best to use the same oil as break-in, run that 500 miles and change to the oil you plan to run in it permanently.
Fox Prepping a '91 to start after 5 years sitting?
  • 331strokerGT
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2026
limp
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
