Fix a flat can how does this work?
mat82284
889
i just got a flat tire from a screw and wanted to know what that can does? does it actually fix a flat or just pump it up im guessing pump it up. anyone ever use this product before how does it work?
fix-a flat is a can that you spray in your tire through your valve stem, and it coats the inside and seals it up.
you might be thinking of tire plugs (which work wonders) where you remove the screw from the tire, widen the hole, then insert the glue soaked plug and snip the excess
Use it for payback. If someone pisses ya off, get ya abotu 8 cans of that stuff, and put 2 in each of his tires. At night so it has time to settle at the bottom. Next morning, the victim gets up, starts to leave, and can't figure out why cars riding like **** (tires out of balance.) :)
90 Red - remind not to do anything to upset you! :)
Others said it - it's a temporary fix to be used only in an emergency. Get the flat fixed properly, or get a new tire if it can't be repaired. Use the fix a flat only if you absolutely have to.
