FIX OR REPLACE??
  • Thread starter Thread starter ShAkE N BaKe!!
  • Start date Start date Sep 9, 2007
ShAkE N BaKe!!
144
  • Sep 9, 2007
Im in the process of my front disc brake swap and was wondering, now that everything is off should I just replace my upper ball joint or replace the whole upper control arm or just rebuild them? The upper control arm frame is straight, but was just wondering if I would be better of replacing it now?
-Im also going to replace my lower control arm
M
mustangman1974
463
  • Sep 9, 2007
Considering the arms are pretty cheap I would save time and replace the whole thing.
ShAkE N BaKe!!
144
  • Sep 10, 2007
is it true that new arms are thinner and have fitting issues?
ShAkE N BaKe!!
144
  • Sep 10, 2007
are they worth rebuilding for a daily driver?
D
D.Hearne
11,730
south louisiana
Sep 10, 2007
  • Sep 10, 2007
I'd never rebuild the old ones, new ones are the way to go.
88gt
794
Drillers cabin
Sep 10, 2007
  • Sep 10, 2007
I purchased new ones when I rebuild the front of my '65, fit great and was so simple compared to rebuilding the old ones. Just remember to keep track of you shims and where they were so you came put them beck in the correct location and keep your alignment close enough to get you to the alignment shop.
Jim
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
Which Lakewood Front Struts Would Work the Best?
  • 93gtmustang
  • Nov 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2025
Ethereal_Zer0
E
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
