fixing the frame rail
  • Thread starter Thread starter Cobain03
  • Start date Start date Nov 29, 2004
Cobain03
996
Lexington, Ky
Nov 29, 2004
  • Nov 29, 2004
my rear bushing is shot and is partially rusted through. whats the procedure to fix this?
krash kendall
1,258
Aldergrove, B.C. Canada
Nov 29, 2004
  • Nov 29, 2004
And you thought the pitman arm/headers were a problem.
67coupe351w
424
Portland, OR
Nov 29, 2004
  • Nov 29, 2004
What exactly is shot? The tube that the rubber bushing pushes into on the frame?
Cobain03
996
Lexington, Ky
Dec 1, 2004
  • Dec 1, 2004
the hole that the bushing goes int
i thought i could get another rail and cut and weld another into place with some bracing ??
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Dec 1, 2004
  • Dec 1, 2004
the bushing has a steel sleeve around it, are you sure the frame is rotted and not just the bushing?
Cobain03
996
Lexington, Ky
Dec 1, 2004
  • Dec 1, 2004
yeah its the rail it is rotton gone anound it poke your fingure in in
65stanger
big blue fuzzy closet monster
3,885
In the Deepest, Darkest, corner of THE CLOSET, whe
Dec 1, 2004
  • Dec 1, 2004
I had to replace the rear section of my frame rails. First step is to buy the section(s) you need, then if you feel comfortable welding on your car, you proceed to cut (using NEW section as a guide) out the old rail section, fit and weld in the new section.
OR, if you don't feel comfortable doing this repair yourself, find a shop that can do it for you.
Another question.....You say your frame rail is rotted, How is your trunk floor, trunk floor drop-off, and lower rear quarter panel?
My experience has shown that frequently, when the frame rail is rotted, you'll have rot in these areas too!
Cobain03
996
Lexington, Ky
Dec 1, 2004
  • Dec 1, 2004
everything is for now the side drop down from the trunk is kind rotten fix that next
but the trunk is ok
oohhh by the way me and my is fixen the header problem this weekend cut and weld,, cut and weld
krash kendall
1,258
Dec 2, 2004
  • Dec 2, 2004
It is the header you're going to cut and weld and not the pitman arm, right?
302 coupe
1,952
Macon, Ga.
Dec 2, 2004
#10
  • Dec 2, 2004
  • #10
There's nothing like working around a problem rather than fixing it!
krash kendall
1,258
Dec 2, 2004
#11
  • Dec 2, 2004
  • #11
If your are referring to his pitman arm/header problem I completely agree. Cobain, you should probably start a new thread with your repair plan before cutting any good/expensive parts up and see what advice is out there. There are thousands of p/s cars out there with tri-y's.
65stanger
3,885
Dec 2, 2004
#12
  • Dec 2, 2004
  • #12
Not to mention your TOP priority should be repairing your rotted frame rail before it completely disintegrates and you lose your rear suspension, drive shaft, etc., with it!
krash kendall
1,258
Dec 2, 2004
#13
  • Dec 2, 2004
  • #13
You're right BBFCM. Safety supercedes dressing up the exhaust.
Cobain03
996
Lexington, Ky
Dec 2, 2004
#14
  • Dec 2, 2004
  • #14
no one on this forum, i mean no one that has posted, knows anythign that can fix my header problem. i've posted for abuot 3 weeks straight trying to find a fix but not a thing. i will prolly be doing the frame and header in the same day btw
Paint and Body Rust what to do now
  • 97sn95
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2026
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
J
67 GTA / Shelby tribute mishmash ?
  • Jacksstang
  • Aug 27, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Aug 27, 2026
General karthief
Resolved 83 frame rail damage?
  • x_man586
  • May 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 14, 2026
General karthief
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
