Flashing battery light
  • Thread starter Thread starter 00GTpony
  • Start date Start date Sep 22, 2007
00GTpony
162
  • Sep 22, 2007
Friends mustang, his battery light is flashing, also car started backfiring along with the flashing light... any ideas ( battery is 2 weeks old )
Beasty306GT
671
Oxford,Mass
Sep 22, 2007
  • Sep 22, 2007
altenator is junk...bring it somewhere to have it tested...
00GTpony
162
  • Sep 22, 2007
tested it, working fine, the machine said to change battery... but brand new?... he has alot hooked up to the battery tho, as well as the car, mayb the battery isnt strong enough?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 23, 2007
  • Sep 23, 2007
If thr battery voltage drops too low, it will not supply sufficent power to the alternator field windings. Then the alternator will not put out the full 13.8-14.2 volts needed to make everything run good.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Sep 23, 2007
  • Sep 23, 2007
Check voltage of battery when car is idling. Trun all the accessories on and check voltage.
Clean every connection from the batt to the starter solenoid. Replace battery terminals or any cable if questionable. Make sure everything is tight.
Load test the battery.
00GTpony
162
  • Sep 23, 2007
load test- done, ide - done, everything past, but the machine said, replace battery. so i dunno
G
2000 GT- Alternator not charging
  • grugug
  • Nov 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 12, 2026
squeak93
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
