tested it, working fine, the machine said to change battery... but brand new?... he has alot hooked up to the battery tho, as well as the car, mayb the battery isnt strong enough?
If thr battery voltage drops too low, it will not supply sufficent power to the alternator field windings. Then the alternator will not put out the full 13.8-14.2 volts needed to make everything run good.
