banditmwp New Member Jan 9, 2004 218 1 0 Opelika/Auburn, AL Feb 13, 2004 #1 Feb 13, 2004 #1 Does anyone happen to know the CFM flow of air on a stock 5.0HO fuel/air induction setup? Just curious...i would guess about 600 CFM but if anyone knows for sure it would be most appreciated!
banditmwp New Member Jan 9, 2004 218 1 0 Opelika/Auburn, AL Feb 13, 2004 #2 Feb 13, 2004 #2 PS...fuel pump, regulator, and injectors are stock too!!
CRASH7772 Member Apr 27, 2003 401 1 16 NH Feb 14, 2004 #3 Feb 14, 2004 #3 http://www.jason.fletcher.net/tech/specifications/specs2.htm
9 90Notch Founding Member Jan 31, 2002 1,046 0 0 Westwood, MA & yes it's killing me that I'm no Feb 14, 2004 #4 Feb 14, 2004 #4 "i would guess about 600 CFM but if anyone knows for sure it would be most appreciated!" Well what do you want fuel flow or air flow? CFM is used for airflow not fuel, stock fuel system (EFI) uses 19lb/hr injectors at 39psi (w/vacuum off).
banditmwp New Member Jan 9, 2004 218 1 0 Opelika/Auburn, AL Feb 14, 2004 #5 Feb 14, 2004 #5 thanks...found the answers i wanted in crash's link!!
