Flowmaster Part # Check
  • Thread starter Thread starter 5.0 Drop Top
  • Start date Start date Dec 11, 2003
5.0 Drop Top
86
  • Dec 11, 2003
Can someone confirm that this is the flowmaster 40 series muffler that will fit my 91 5.0 LX Convertible?
42441
Thanks.
L
loboboy
Dec 11, 2003
  • Dec 11, 2003
If you are looking for the 2.25 in and out then that is the p/n but if you want the 2.5 in and out you need the 42543
BADPONYsc
884
Florence, SC
Dec 11, 2003
  • Dec 11, 2003
No, those are 2.25" offset inlet/ center outlet, which would only work if you were going to use dumps instead of tailpipes. I've used that style with dumps before, but with 2.5" inlet/outlet. 5.0 Mustangs use offset inlet AND offset outlet.
42443 = 2.25" offset inlet/outlet
42543 = 2.5" offset inlet/outlet
If you've got stock size (2.25") exhaust parts... h-pipe, flowtubes, tailpipes, then the 2.25" mufflers will be fine. But if you've got upgraded 2.5" tubing, use the 2.5".
Hope this helps.
5.0 Drop Top
86
  • Dec 11, 2003
Will a mechanic be able to work with a 2.5 inlet and outlet muffler if I have stock 2.25 tubes?
Will measuring the tailpipe give me an accurate measurment of the tubing diameter where the mufflers connect?
BADPONYsc
884
Florence, SC
Dec 11, 2003
  • Dec 11, 2003
If you use 2.5" mufflers with 2.25" tubing, what most shops are going to want to do is just slip the tubes into the mufflers and fill in the difference with weld. This will work, but it will be ugly looking. The alternative would be to remove the flowtubes from the H-pipe, remove the tailpipes, stretch the inlets of the flowtubes and tailpipes up to a 2.5" diameter, then re-install everything, line it all up, then weld it all. That's why I say, most shops are going to want to just throw the mufflers up there and fill in the cracks with weld. If you don't care how it looks, then go with that.... I mean, it's under the car right? Noone's going to see it.
2.5" mufflers with 2.25" tubing isn't as big a deal as having mufflers with the wrong inlets/outlets. If you try to put mufflers on a mustang with either a center inlet or center outlet, they'll have to take a piece of scrap tubing, angle it between the muffler and the tubing and fill a bunch of angled gaps with weld and that's really ugly... this is all IF you can find a shop that would even do it.
The best thing is to get the proper sized mufflers that match your tubing, get a nice tight slip-fit, then have minimal welding. Then you know it's nice and clean and that the same amount of flow is maintained throughout the whole system. I've experimented with a bunch of different exhaust setups because I have good friends who own a Meineke shop and it didn't cost me anything, except buying mufflers, etc and I know it feels better to do it right and know it all fits nicely and is a clean job. I've had some crazy stuff and ended up not liking it.
Hope this helps!
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
C
Drivetrain TV cable replacement--aftermarket or search other models?
  • chazmanaz
  • Dec 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
AeroCoupe
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Electrical need help with a part number
  • alutwon
  • Jan 27, 2026
Fox 5.0 Mustang Tech Jan 27, 2026
alutwon
M
Hey all
  • Mikalikey
  • Aug 20, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 20, 2026
Mikalikey
M
