flywheel position problem
gotta2s
turlock
i bought a centerforce clutch for my 93 mustang gt. i had the flywheel resurfaced, and when i put it back on i noticed a weight on one side. i didnt pay to much attention to it. now my car rattles quite a bit, mainly from the shifter. i had also put a drive shaft from a 98 mustang cobra. i have already taken that to be ballanced thinking that might be the problem but no success. now im thinking its the weight on the flywheel causing it. i was told there is only one way the flywheel will bolt up due to the bolt pattern and thought i just got lucky on the first try. reciently someone else told me differently but they wernt sure which way the weight needed to go. if anyone knows which way to properly mount the flywheel i would greatly appreciate the info.
thanks.
Your flywheel will only bolt up to your crankshaft in the proper position. The bolt holes are spaced differently for this purpose. It could be your drive shaft to rear yoke position. It could be any of four possible ways. Change it until the vibration gets better.
