Flywheel problems
Montana
Ga
Hello everyone. I am having trouble figuring out what flywheel to use in my 66 coupe. It has the original c4 transmission and bell housing but I have put an 86 5.0 H.O in it. Does anyone know what flywheel I should use?
you will use the flexplate from the later engine with the 50oz balance factor. you also need to match the tooth count on the flexplate with that of the bell housing, and that is 157 teeth.
