Flywheel
  • Thread starter Thread starter 66mustangg
  • Start date Start date Nov 24, 2006
66mustangg
59
Westchester, NY
Nov 24, 2006
  • Nov 24, 2006
im swapping a 351Clevland into my 69 mustang which has a I6 with the original 3 spd tranny... what flywheel will i want to be using with the 351 and i cant reuse the one from the I6 right??
thanks
D
D.Hearne
11,730
south louisiana
Nov 24, 2006
  • Nov 24, 2006
Depends on what bellhousing you're using. There are two size bells for the Cleveland, either 157 tooth or 164. The six flywheel's neutral balanced, can't use it on a Cleveland. The Cleveland uses the same flywheels the 289/302 uses---28 oz/in.
66mustangg
59
Westchester, NY
Nov 25, 2006
  • Nov 25, 2006
how do i find that out???... its a bellhousing out of a 72 mustang
D
D.Hearne
11,730
south louisiana
Nov 25, 2006
  • Nov 25, 2006
What engine did the bell come off of ? 302 or a 351 ? If it's a 351, it's likely a 164 tooth bell, 302's usually had 157's. You could do a little searching on ebay for "Ford Bellhousing" and see what's listed there as to the casting number and what bell is what.
Flywheel
  • Barry
  • Mar 10, 2026
1974 - 1978 Mustang II Talk & Tech Mar 11, 2026
Barry
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
P
Engine Help 331 stroker
  • pdmount
  • Feb 19, 2026
Fox 5.0 Mustang Tech Feb 21, 2026
pdmount
P
