  • SN95 4.6L Mustang Tech
FML whats wrong with my trans????
  • Thread starter Thread starter 1996droptop
  • Start date Start date Apr 29, 2011
1996droptop
9
  • Apr 29, 2011
ok so i swapped out a 01 gt 4.6 into my 96 gt keep all my original intake and top stuff pretty much swapped from valve covers to oil pan every thing runs good but when i put the auto trans in to gear nothing i put 6.5 qts in it and nothing i didnt pull pan and i topped off torque converter i have a 4r70w what to do????
trinity_gt
3,125
81
99
Canada
Apr 29, 2011
  • Apr 29, 2011
Was the converter properly seated before you installed the trans? Did the input shaft splines and the pump teeth both engage properly?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 29, 2011
  • Apr 29, 2011
Isn't the fluid capacity something like 12 quarts? I could have sworn it was, and that could definitely be your problem if you're low on fluid.
bhuff30
6,037
35
129
Olathe KS
Apr 29, 2011
  • Apr 29, 2011
I was going to say something about fluid too. Most automatics seem to take at LEAST 8-10qts. Let the car idle for a while, top it off and try going through the gears again. It takes a while to get oil through the whole system. The converter, trans cooler and cooling lines can hold a lot of oil.
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
