OMG OMG OMG what a difference. I'll give the quick story in case anyone else is considering putting shocks/springs on. I used many of the threads on stangnet to figure this out, never done it before today. Whoever had the car before me was a moron, had chopped the springs unevenly, even to the extent that the passenger front was 1 inch shorter that driver front, Isolaters were destroyed, and shocks were still the stockers.
Started at 0700 am, tried to remedy a problem I'm having with my rear end leaking due to bottom bolt being broken, NO luck. Anyways, rear shocks and springs were suprisingly easy. Only minor trouble I had was the driver side shock top nut was a pain to get off, ended up using vice grips so bolt wouldnt turn. Springs fell out easy, and were simple to put back in.
The front ones were a whole different story. First off, my cheap impact wrench didnt have the gonads to get the bottom two shock bolts broke lose, so off I went to Sears (fearing the wrath of my wife) and bought me a Craftsman ($159). Got back home, and this wrench is my new found love, so strong it shredded two of my cheaper impact sockets, and had no problem gettting the bolts out (600lbs max torque in reverse). Anyways, got everything down, and for all my might, I couldnt get the spring pried out, so back to town I went to get a tie rod puller so i get get the arm down lower. This did the trick and I got the driver side done after about 4+ hours. Passenger side was considerably easier, only other hang up was that I have NEVER messed with brakes before, so i had to read up about compressing the cylinder to get the calipers back on.
Whole job took me from 0700am this morning to 0800pm tonight (given I'm an amateur, had to make two trips to get what I needed, and had to run back and forth between computer to read up on it)
Have only taken the car around the block so far, and it feels like a whole new car, no vibration in steering wheel, corners better than ever, and ride is super smooth. I havent got a chance to even play with the settings yet, front is on 2 right now and back is on the softest setting (1 I think)
Anyways, if you are thinking about doing it, DO IT, I'm no mechanical genius by any means and made it through, and I think I'll be very happy I did.
