fog light fix?
  • Thread starter Thread starter U2SLO450
  • Start date Start date Aug 25, 2006
U2SLO450
118
  • Aug 25, 2006
I own a 90 gt and was wondering if it was possible to wire the fogs to a toggle switch and to like the battery or whatever so you could run the fogs without having on your headlights?
Nopantz
234
NJ/US Merchant Marine Academy
Aug 25, 2006
  • Aug 25, 2006
there is a way go here http://www.corral.net/tech/maintenance/foglights.html should help u out
bubba-dough
1,044
Indiana
Aug 25, 2006
  • Aug 25, 2006
U2SLO450
118
  • Aug 26, 2006
can't you just run a wire from the fogs to the battery and to a toggle switch like people do when they dont' have factory foglights?
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Aug 26, 2006
  • Aug 26, 2006
the corral fix is the best way....very clean
HISSIN50
34
129
Aug 26, 2006
  • Aug 26, 2006
Well sure you can. The idea is to have a clean install that looks OEM, and uses a relay for better lighting output and decrease of electrical hazard. You'll find that most decent driving light kits come with a harness and relay as well. They dont do that because they're nice - they do it because the battery and switch method is horrid IMHO.
Good luck.
Nopantz
234
Aug 26, 2006
  • Aug 26, 2006
we could always start a poll on which way everyone has done it....I havent done it yet but i will probably do it the corral way when i do....its juss cleaner....something about juss hooking to the battery and a toggle switch doesnt always sound great
U2SLO450
118
  • Aug 27, 2006
tried it that way, blew two fuses. Had to go the corral way, should have done it that way to begin with. But it was cool running the foglights ONLY, for 2 seconds.
02TruBlueGt
  • Aug 28, 2006
my fogs just dont work in general any things u guys could suggest the fuse is good and when i turn the on the volt gauge doesnt move like it isnt even drawing power??
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 28, 2006
#10
  • Aug 28, 2006
  • #10
Check the bulbs to make sure they are good & clean the bulb sockets & electrical contacts with non-flammable brake parts cleaner. It is the same stuff as electrical contact cleaner in a bigger can, cheaper too.
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
