Fog Light ReWire... Help!
  • Thread starter Thread starter FastStang 2
  • Start date Start date Mar 25, 2007
FastStang 2
42
  • Mar 25, 2007
I have a 1993 Ford Mustang GT.
I have been following some instructions at the following link:
http://www.allfordmustangs.com//Detailed/625.shtml
I got to the point where it says:
Now take the light brown with orange and cut it. Connect the 18 gauge grey wire to the side going to the switch, then connect the yellow 18 gauge to the other side of the light brown /orange wire.
I do not see the 18 gauge gray nor yellow wires that are being described.
Here are some pictures of the wires I have:
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 25, 2007
  • Mar 25, 2007
there is a good write-up on corral about this
Aryan15
236
CA
Mar 26, 2007
  • Mar 26, 2007
I just used the wire going to the fog lights to energize the relay. That way they will come on only if the headlights are on and the fog light switch is closed. Not with parking lamps like they suggest. Its the wire in the fog light plug that is not hot with the headlights on. Good luck.
FastStang 2
42
  • Mar 27, 2007
I retrofited the relay and still do not get any power to the fog lights.
HISSIN50
34
129
Mar 27, 2007
  • Mar 27, 2007
Hmm, that article is not the easiest to scan through.
What is the output terminal (87) showing with the circuit powered up? It should show 12 volts.
86 and 30 should also show 12 volts.
Ensure 85 is grounded.
If those are all there, double check that the correct wire at the fog light switch was cut (and that the output power is going down the correct wire to the fog lights).
Good luck.
gunmetal5.0
144
Chico, CA
Mar 27, 2007
  • Mar 27, 2007
Is it the grey/yellow and yellow wires on the ignition switch that they're talking about?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 27, 2007
  • Mar 27, 2007
I did the same thing and tapped into the foglight wiring under the hood. I mounted the relay and fuse under the hood next to the battery. No wires to chase or run through the firewall. I have 12 gauge wire for the foglight power and ground. The lights are really bright and I think it is because there is almost no voltage loss with the relay & 12 gauge wire.
Aryan15
236
CA
Mar 27, 2007
  • Mar 27, 2007
I also had to do the relay setup in my tempo with just the headlights. Im dissapointed in these ford headlight systems.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Mar 27, 2007
  • Mar 27, 2007
just thought id post the corral one. I folled it and it was a piece of cake. It has pics
http://www.corral.net/tech/maintenance/foglights.html
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
J
Shift light
  • Jfriedrich
  • Jun 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 29, 2025
dirk shorter
D
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
