Are there any common problems with the foglights? (possibly the switch or a relay) I changed the bulbs today and they still don't work and I can't find an fuses. I haven't checked for voltage but thought I would just ask!
if its stock everything still they tend to have a bad overheating and shorting problem because the stock switch cannot handle the current. Id be willing to bet that if you took out the switch your connector may be rather distorted and melted
this is awesome because you basically just use your factory switch to switch on/off a relay that takes care of the larger fog light draw..and you can use them with your parking lights...its very simple
Fog light fuse is #15, but you also want to check into the fog light mod mentioned. It's cheap and easy to do while things are working, but can cost you time and money in repairs if you wait for circuit failure.
