hey again, i am in iraq...yet again.
I moved to a new base today and picked up a magazine for something to read on the helo and whatnot...and saw the most amazing thing.
a 400m from john kaase won 2 years running. stock production station wagon block. stock crank stroke and bore.
he used the same exact setup we spoke about earlier right down to the plastic spacer between the intake and head with 1 exception...he used a cleveland tunnel ram instead of a windsor. i didnt see that one, because its shorter, but that meant he needed a large plastic spacer (yay..better for the intake cooling). you should be able to place your hand on the intake manifold while the engine is running and not get more than 15 degrees above ambient temp.
that engine was a beast!
500-597 ft-lbs from 3000-6800
500 + horses from 4600 to who knows when..he stopped it at 7k and it still had 632 horses.
597 torque
677 hp
on motor alone...
quite impressive.
most expensive thing about the build were the heads. everything else could be found in a scrap yard or someones garage for next to nothing.
2.2:1 rocker ratio was prolly expensive on cleveland heads too.
2.22 intake valve (insert 64 ounce big gulp cup here)
same length as a windsor, just 1 inch wider than windsor and only 125 lbs heavier.
for the main stream guy, why worry, but for those who want to be different...
imagine what this would do with a fast dual throttle body retro setup with a phat turbo or procharger blower feeding each throttle body?
sick top end.
thank you for your time..
peace out from iraq
rowdy j
597 torque
677 hp
on motor alone...
quite impressive.
sick top end.
peace out from iraq
rowdy j
depending on the head (the 4V flows more than the 2V cleveland head, and no it doesnt have anything to do with the quantity of valves per cylinder...) they have serious horse power making potential.
