Well do to a resent trajedy in my family I am selling my pride and joy. Its an 03 azure blue mach 1 5spd with only 6180 miles on it. The car puts down 425 RWHP and 396 RWTQ. The car was tuned by Tim @ Modularpowerhouse, the car has the following mods.
P1-SC 8psi/intercooled
42lb injectors
aviator fuel pump
lightning MAF
Iridium plugs
DR gas X pipe
Magnaflow cat back 3.5 inch tips
steeda Tri-ax shifter
aluminum driveshaft
drive shaft loop
Maximum motorsports subframe connectors(welded)
steeda comp springs
strange 10way adjustable shocks and struts
steeda Heavy duty UCA's
Metco LCA's
eaton differential
3:73 gears
moser 31 spline axles
3inch rear wheel studs
welded boxs and tubes
a-pillar guage pod with boost and fuel pressure
raptor shift light, mounted in head liner
rear seat delete
18 inch chrome replica's with 265's all around/not mounted in pics
All original parts minus exhaust and suspension plus stock rims and tires with BFG DR's mounted on stock rims. I am asking 27,000 OBO If interested email me at [email protected]
42lb injectors
aviator fuel pump
lightning MAF
Iridium plugs
DR gas X pipe
aluminum driveshaft
drive shaft loop
steeda comp springs
Metco LCA's
eaton differential
3:73 gears
rear seat delete
