  • 1994 - 1995 Specific Tech
Fox Blocks and Sn95 blocks question
  • Thread starter Thread starter stevinwayne
  • Start date Start date Aug 22, 2005
stevinwayne
78
  • Aug 22, 2005
is there any difference between a 94 5.0 block and an 89 5.0 block?
HISSIN50
34
129
Aug 23, 2005
  • Aug 23, 2005
The packaging is different (intake, TB, inlet, accessories, etc). Here is some info in a current thread.
stevinwayne
78
  • Aug 23, 2005
but lets say i have a block that i'm building a motor for and i remove my sn95 engine and unbolt all the accessories, can i just bolt them (in the same order) to the fox block?
Killercanary
The car that set the bar.
Altoona, PA
Aug 23, 2005
  • Aug 23, 2005
Yes. The blocks themselves are the same.
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Aug 23, 2005
  • Aug 23, 2005
I just finished that exact swap. The blocks are the same except a few minor differences. You'll want to use your SN95 timing cover and water pump. Fuel rails are different. Distributor can work but the SN95 looks better. Behing the timing cover is the timing chain. On the bolt that is in front of the camshaft in the 89block, there's a small bracket. Unscrew the bolt and remove the bracket cause it will hit your SN95 timing cover/waterpump.
The lower intakes are almost the same. You'll need to install a couple plugs o the 89 lower. And yes the accessories will bolt right up to your 89block. You just need to re-use your SN95 brackets.
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
2nd Fox Body
  • N8827N
  • Jul 17, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 18, 2026
91AOD5.0LX
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
