Fox valve cover, Vortech, and strut tower brace
i'm not sure if this will work or not but can you cut the oil fil tube then put a short s bend rubber hose on then attach your breather to it ? :shrug: pauls car i has that problem too. i moved my filler to the back of the pass. side valve cover behind the throttle body .
I had a similar problem with my aftercooler hitting the breather on the passenger side, so i swapped valve covers, and had a welder fill in the old breather hole, and had them weld in a new moroso breather.
