  • 1994 - 1995 Specific Tech
Foxbody throttle body swap
  • Thread starter Thread starter 95mustang_gt
  • Start date Start date Nov 20, 2005
9
95mustang_gt
364
Wisconsin
Nov 20, 2005
  • Nov 20, 2005
Im going to be doing the fox throttle body swap.Can i use my T-body cables or do i need to switch to foxbody cables?Does it have to be a auto accelerater cable or can i use a 5speed cable?I hear that i have to switch to a foxbody computer?
Thanks
Jesse
illwood
636
Worcester, MA
Nov 20, 2005
  • Nov 20, 2005
There are some threads with good info on this, so a search would help alot.
A fox throttle body cable will help. And I don't know what the difference between the throttle cables for the auto and manual transmissions. You don't have to switch to a foxbody computer. You will have to:
-block your header egr or run fox headers
-run a fox EGR valve or do an EGR delete
-modify your harness on your TPS to accept a fox style TPS
-run a fox IAC
shelbe67
309
Nov 20, 2005
  • Nov 20, 2005
you dont need the computer the throttle cable from an auto or stick is fine do a search b/c you have to splice the new tps in so you need the color code
RIO5.0
6,892
N.H.
Nov 20, 2005
  • Nov 20, 2005
Here's a pic of the set-up...The cables are way different in the way they connect to the TB...The SN cable wont attach to a Fox TB...
TB installed...
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
D
Throttle Body Spacer
  • dropteeth
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
nicholase
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
