FP Eccentric rubbing timing cover?
  • Thread starter Thread starter stangbuilder66
  • Start date Start date Sep 29, 2007
stangbuilder66
25
  • Sep 29, 2007
Hey guys, I bought a classic mustang with a 69 302 off a guy. I am tearing down the engine, the first 302 I have ever done. Normally I work on I-6 300's, so I am wondering about this problem. When I pulled the timing cover, there is a wear pattern from the fuel pump eccentric. It isn't too deep of a gouge, just enough to feel it when I run my finger over it.
My question is if I need to replace the eccentric with a narrower one, or if my cam might have had too much play in it. The thrust plate was installed and doesn't appear to be worn out, and it was tightened down. Is wear on the cover normal?
For the record, I never heard the engine run. I knew it smoked when I got it, and got a great deal on the car so I just hauled it into the garage and started to tear it down.
Suggestions?
HISSIN50
34
129
Sep 29, 2007
  • Sep 29, 2007
All I can tell you is that the eccentric has interference issues with a 94-95 302 timing cover (the eccentric must come off in that application). Just in case that is what the previous guy did................
Otherwise, I dunno' what is going on with yours.
Good luck.
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Project Fox Revival (please send help)
  • sleep-e
  • Jan 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
KRUISR
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
