which one should i go with american muscle has the ford racing one for 6 bucks and two different royal purple brands which are synthetic for around 17 bucks .i want the best for this 8.8 rear end which i'm about to change the seals on.
You mean the diff fluid?
Royal purple... you can get it for the same price at Oreilly's though. Saves time.. You still need a small bottle of friction modifier to add to the mix. Also at Oreilly or get it at Ford dealer..
I just did mine today.
no you dont its pre mixxed in
Wonder why LRS includes 2 bottles of Royal Purple + friction modifier in their gear installation kits?
Max-Gear is recommended for use in truck, motor home / RV, and automotive front or rear differentials, manual transmissions, and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary.
We include a bottle of Friction Modifier because even though the Royal Purple Oil has an amount of friction modifier in it's formula, some differentials will still exhibit the popping clutch syndrome on turns that is indicative of no friction modifier being used.
thanks for clearing that up john! go smack alex in the back of the head for me
