like the title say how in gods name do you get them back in i got the compresser that goes inside the spring and the spring is compressed but how do you get it into the upper pocket now? Please any help is appreciated iam at my wits end
Very good advice here. The clam shell compressor is the way to go (I was unable to locate one when I did mine). Are they pricey?Shakerhood said:If you have the correct spring compressor it has 2 flat plates and a threaded rod that goes up through the center. If I remember right the forcing nut on the shaft is 21 or 22 mm. Its really easy once its cranked down and in place with the springtail between the 2 holes in the lower A Arm. Just loosen the focing nut until the pressure is relieved and then slip the plates out of the coils.
I am too poor for that, but it sure is nice to have the right tool for the task!Shakerhood said:Yes, it was over $200, but well worth the investment for me as it made my spring swap so much easier.
Son, you got brass!rsw007 said:compress the spring outside the car get several wire coat hangers and strap the spring with the wires remove compresser then install, bolt it up, then cut wires and pull them out. saffer if you can band them with with banding materials. JUST BE CAREFUL
and i hope your homsexual tendencies cause you to contract aids douche bag95cobradude said:isn't this funny, i'm here giving u help and u called me a gaylord because i dont agree with that redneck killing those innocent "yotes", as i guess hicks call them. i take all my help back and i hope u have to have your car towed somewhere and pay out the ass to have them put in right, better yet i hope that ****in spring flies out and decapitates your stupid ass. u have no business in these forums if u cant even put in a set of springs u chowderhead.
If you want ancillary or extra info, MFE has a pretty nice write up on this method. Good luckaxeman said:Grow up people.
The way I replace front springs is to remove the bolts that bolt the A-arm to the K-member. No spring compressors needed.
can you elaborate on that did you drop the control arm and then use a jack to push it up ? i have never done springs before and the ford motorsport c springs are very much shorter than stockers so i dont know what to doaxeman said:Grow up people.
