Front Disc Brake Kit Winter Special
  • Thread starter Thread starter degins
  • Start date Start date Oct 15, 2006
1 of 2 Next Last
degins
361
Texas
Oct 15, 2006
  • Oct 15, 2006
All members,
The forum moderator has been so kind as to grant me permission to offer StangNet members $100 off the normal cost of the CSRP SWAP.2 and SWAP.3 front disc brake kits. The special price will be $445 + S&H.
The kits are based on the tried and true Ford Granada design spindle and bracket. Unlike other available Granada kits, CSRP offers all new parts with correct suspension and steering geometry for both 65-66 (SWAP.3) and 67-73 cars (SWAP.2). No "Granada" related bumpsteer issues on 65-66.
The kit includes all of the parts necessary to do the swap including:
-A rebuilt master cylinder.
-An adjustable push rod (new added content worth $40).
-An adjustable proportioning valve.
-Hoses with fittings correct for the year applied.
-Original type hose to chassis L-bracket and hose clip (new content valued at $18).
-New calipers with zinc/chromate corrosion protection.
-Semi-metallic pads.
-SLOTTED rotors.
-Bearings and seals.
-All the necessary wheel and caliper small parts.
-New high strength alloy disc brake brackets and large pin spindles.
-New splash shields, shield flanges and bolts.
-New outer tie rods correct for most applications including ones for manual 6 cylinder and manual and PS 8 cylinder (PS tie rod cost $80 at Mustang Plus).
-Access to our complete installation guide is included. The only thing not included are the short pieces of brake line necessary to adapt the system to the existing lines.
The kit is guaranteed against manufacturing defect for 12 months and free tech support is included via the internet.
The kit IS offered with 65-66 OR 67-73 specific spindles.
S&H runs $28-$75 depending on location. This price is for payment via money order or e-check. Credit card payment is offered for an added $15. TX sales tax applied to deliveries within Texas. I have inventory to cover all orders, and I will ship the Forum generated orders once per week.
If you wish to order, please write me at info@discbrakeswap.com and mention the StangNet offer. I will need to know your zipcode, the year and model of your application, if it has power steering, if you wish to receive a power or manual type master cylinder, and how you intend to make payment. The kit does not include a power brake booster.
Kits are also available for Falcon, Fairlane, some Torino, Maverick, and 50's Fords (with some mods).
Write me here or at info@discbrakeswap.com if you have questions.
Thanks,
Dennis
JC6715
284
Hillsboro, Oregon
Oct 18, 2006
  • Oct 18, 2006
How long will you be running the special?
degins
361
Texas
Oct 18, 2006
  • Oct 18, 2006
I plan on at least 4 weeks.
I have just received a shipment of new reproduction components that I have had manufactured. I am trying to increase the ease of installation of the kit. With that in mind, I now include an adjustable push rod and original (to 65-66) brake hose to chassis brackets and the clips that secure the hose to these brackets. The parts would cost at least $50 at the leading parts houses. They are included in the SWAP kits at no extra cost.
12sec67
1,301
San Diego, Ca
Oct 24, 2006
  • Oct 24, 2006
sent you PM
hotrodredneck
200
Newport News Va
Nov 19, 2006
  • Nov 19, 2006
E-mailed ya.
R
Randy'65
352
Richmond, VA
Nov 23, 2006
  • Nov 23, 2006
Is the MC in the 65 kit a single or double bowl MC?
krash kendall
1,258
Aldergrove, B.C. Canada
Nov 24, 2006
  • Nov 24, 2006
It has to be double.
degins
361
Texas
Nov 24, 2006
  • Nov 24, 2006
It includes a disc/drum dual reservoir MC.
MarksFastBack
10
  • Nov 28, 2006
Paying for mine in a couple days...Pretty excited to get them insatalled in the 65...Thanks Dennis!!
R
Randy'65
352
Richmond, VA
Nov 28, 2006
#10
  • Nov 28, 2006
  • #10
Why? SSBC sells a single bowl MC with one of their kits.
bad68coupe
220
Richardson, TX
Nov 29, 2006
#11
  • Nov 29, 2006
  • #11
is this offer still good?
degins
361
Texas
Nov 30, 2006
#12
  • Nov 30, 2006
  • #12
Yes, until December 15.
Dennis
Randy'65
I choose for safety reasons not to sell a kit with a single reservoir master cylinder. Unless you install a KH clone, originality is not an issue.
red302
881
Peru, IL
Dec 2, 2006
#13
  • Dec 2, 2006
  • #13
Dennis,
What is the difference between the master cyl. provided in the kit for the '68, and the stock dual reservoir master cyl. with drum/drum brakes?
degins
361
Texas
Dec 2, 2006
#14
  • Dec 2, 2006
  • #14
red302 said:
Dennis,
Disc/drum type MCs are different in two ways from drum/drum MCs.
On a disc/drum MC the rear reservoir (for the front brakes) is larger to accomodate the larger fluid requirement of the front brake's calipers and it doesn't have a residual pressure valve.
If your question is leading to if you can use the old MC, the answer is no.
red302
881
Peru, IL
Dec 2, 2006
#15
  • Dec 2, 2006
  • #15
That would have been my next question. Thanks.
stang66convt
29
#16
  • Dec 4, 2006
  • #16
14 in style steel
will this kit fit 14in style steel wheels..a lot of systems will not work with these wheels
degins
361
Texas
Dec 4, 2006
#17
  • Dec 4, 2006
  • #17
It won't.
yeloxr7
429
#18
  • Dec 5, 2006
  • #18
I tried this a few years ago and can back Dennis up on his answer.
The outer diameter of the bearing snout of the rotor is too big (can be solved by machining 1/8" off the snout), but I think the wheel hits the caliper as well.
BLK91LX1uponu
172
Sacramento
Dec 10, 2006
#19
  • Dec 10, 2006
  • #19
What is the bore size on the master cylinder. Thanks
degins
361
Texas
Dec 11, 2006
#20
  • Dec 11, 2006
  • #20
O.9375"
1 of 2 Next Last
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Sponsored New J&M Release: 2024+ S650 MagneRide Front Brake Lines
  • MRaburn
  • Mar 6, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Mar 6, 2026
MRaburn
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
