Exciting update from J&M Products – we're launching our new direct-fit stainless steel braided brake line kit specifically for 2024+ Ford Mustang S650 models with factory MagneRide suspension (front only).
Key Benefits:
hotpart.com
Key Benefits:
- Reduced Line Expansion – PTFE inner liner + stainless braid for noticeably firmer, more consistent pedal feel under hard braking
- Direct OEM-Style Fit – Exact factory replication of fittings, brackets, and routing – true bolt-on, no adapters or modifications
- Optimized Flex Length – OEM-spec fittings minimize braided section length vs. universal kits → even quicker response and superior modulation
- Designed for MagneRide – Engineered for GT Premium, Dark Horse, and other adaptive damping trims
- Superior Corrosion Resistance – Fittings with zinc nickel and trivalent zinc plating for maximum durability in harsh conditions
- Abrasion-Protected – Black or clear cover to shield against debris, heat, and wear
- DOT Certified & Pressure Tested – Individually tested for leak-free performance
- Assembled in the USA – Premium quality with limited lifetime warranty
S650 Mustang MagneRide Front Stainless Steel Brake Lines – J&M Products
Upgrade front braking on your 2024+ S650 Mustang with MagneRide suspension using J&M's direct-fit stainless steel braided brake hoses. Firmer pedal feel, reduced expansion, OEM-style fittings for bolt-on install. Black (22591-B) or clear (22591-C) cover. Made in USA, DOT certified, lifetime...
hotpart.com
