  • 1994 - 1995 Specific Tech
front end problems!!!!!!!!!!
  • Thread starter Thread starter 5.0H.O
  • Start date Start date Apr 10, 2008
5.0H.O
25
b'ham, AL
Apr 10, 2008
  • Apr 10, 2008
I just installed a bullit suspension kit and rack and pinion and before all of this i had a popping noise coming from the front passenger side and it stopped and i hit a pot hole hard one time and it has come back even worse what do u guys think control arm bushings or ball bearings
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 10, 2008
  • Apr 10, 2008
Welcome to :SNSign:
I'd bet on a balljoint or broken swaybar end link before thinking a popping was related to the bearings.
HISSIN50
34
129
Apr 10, 2008
  • Apr 10, 2008
Agreed. Tell us when it pops. For example if when backing up and then hitting the brakes, that's almost always an end link. More info will help. Dont forget things like strut bushings (the pothole seated or destroyed it), etc.
Good luck.
5.0H.O
25
b'ham, AL
Apr 10, 2008
  • Apr 10, 2008
it pops while driving down the road when turning hard or pot holes and i just replaced the sway bar and end links with the suspension kit
HISSIN50
34
129
Apr 10, 2008
  • Apr 10, 2008
Have you been under to check and snug down all the fasteners since you did the install?
5.0H.O
25
b'ham, AL
Apr 10, 2008
  • Apr 10, 2008
yes i got under the car today and checked the ball joints and the rubber in between the spindle and a-arm are shot there is nothing left so im gonna replace them thanks alot
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
