  • SN95 4.6L Mustang Tech
Frozen Hood
  • Thread starter Thread starter dksheehan
  • Start date Start date Dec 19, 2005
D
dksheehan
41
  • Dec 19, 2005
I have always garaged me 96gt, but with my new house I have to store it under the porch.
Needless to stay in the Northeast it is frozen solid.
I have intended on starting in once a month for a while, but when I went outside to start it, I found the battery dead.
I tried to pop the hood, but it seemed frozen too.
Does anyone know if there is a way to manually open the hood?
Also, are there any other winter storage methods I should use while storing my covered stang under my porch?
TIA
Dan
F
fellamansteve
108
Seattle
Dec 19, 2005
  • Dec 19, 2005
If you haven't already, you might want to consider putting in a fuel preservative in your gas tank and keeping it mostly full to keep water from condensing in your fuel lines between starts.
ponysarepretty
578
  • Dec 19, 2005
To open the hood, pour some hot water on it.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Dec 19, 2005
  • Dec 19, 2005
TIA
Dan
If you can't park it inside, find yourself a car cover.
You can use a heat gun to remove ice from your hood, as well as other body seams to free them.
D
dksheehan
41
  • Dec 19, 2005
Is there any way to manually unlatch the hood?
The lever in the car pulls, but doesn't make that snap.
timeless2
Admin Dude
202
154
the Shadow Gallery
Dec 19, 2005
  • Dec 19, 2005
The latch and striker are as manual as it gets without forcing something, which will likely result in breakage.
You will have to remove all obstructions from the hood, as to allow the latch to release it.
1LowGT
294
st louis mo.
Dec 19, 2005
  • Dec 19, 2005
use washer fluid,it dont hurt the paint
triggz
1,218
Gadsden, AL
Dec 19, 2005
  • Dec 19, 2005
Hook up a garden hose to the hot-water outlet on your washing machine
I put a tee on mine. It's great for winter washing.
xseler8
619
Montgomery County,Pa.
Dec 19, 2005
  • Dec 19, 2005
If everything is frozen & battery is dead, leave it alone until it thalls a little. Forcing the hood latch could cause more damage. I have a dead battery every year. I jump start it and it recharges.A cover would be good protection..buy a good one and make sure it tied properly or they go sailing. Good luck
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
G
Its starts then stalls
  • gray owl
  • Jan 22, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 25, 2026
gray owl
G
Fox Ideas for Theft Deterrence in Storage
  • Clutchfork
  • Nov 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2025
91AOD5.0LX
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
