FRPP/Eibach Pro-kit and 20" wheels?
you will be fine with all those sizes, but you have to stay around the same height of the factory tires, which is 27.26" tall. we run the FRPP K springs, with 18's and 295/45/18 on the rear, but we wanted a taller tire, and we have no rubbing, or clearance issues at all, even with people in the backseat...
So...no to the 20's.....unless I want rubber bands......that is kind of what I thought....I am fond of the 18's....that is what I have on my 01....its just that the newer body styles have bigger fender openings for bigger tires....
Front Tires are 245/35/20
Rear Tires are 275/30/20...Toyo Makes a 315/35/20 that I will be ordering soon, the 275's stretch to fit the wheel.
That is the CDC Agressive Chin Spoiler and I get maybe a little more then 4 inches of clearance which is plenty for my Daily Driver.
I can measure it later if you really need an exact measurment.
I can take most speed bumps straight on, my driveway has a gutter that is pretty steep and I hit it at a slight angle. I think it would probably make it straight though, not going to try it. I've driven lowered cars for years, the only problem you'll have is driving down rough roads at high speeds...and Armadillos.:rlaugh:
I too am running the prokit, wish I could run sportlines. My rears are a 285/30/20 and are still flush to the wheel well opening. Just that the bodykit is so low I can't even attempt to run sportlines.
