Fuel Cut Off Switch
  • Thread starter Thread starter Blakthorn
  • Start date Start date Jun 23, 2005
Blakthorn
299
US
Jun 23, 2005
  • Jun 23, 2005
After browsing here and corral for a quality fuel cut off switch how too for an 87, I've come up with nothing useful
If someone can direct me to a good How To, It would be greatly appreciated
P
Project89
94
Panama City, Florida
Jun 23, 2005
  • Jun 23, 2005
I saved this from a thread a while back, but I do not remember who's posted this, so sorry for no credit. BTW I have not tried this yet myself. Here goes:
A Fuel Cut-Off switch is one way to stop your car from being started and sense our Mustangs have electronic fuel pumps it is very easy & inexpensive to install a Fuel Cut-Off Switch.
All you need is a simple ON/OFF switch and some wire and an hour or two and you will have installed a Fuel Cut-Off Switch and if it is set in the off position you will not be able to start the engine.
The fuel pump has 2 wires going to it, all you have to do is splice into one of the wires; it does not matter which one, and insert an ON/OFF switch. There are many places that you can splice into these wires and install a ON/OFF switch, that is totally up to you. I spliced into the wires at the fuel pump on top of the gas tank to make it harder to find the splice. You can find the wire and switches you will need at Radio Shack and it should not cost more then $20.00, depending what kind of switch you buy. Hide the ON/OFF switch in a place that only you know about and is not easily seen. If you have any questions PM me and I will be happy to help you out. Below is a diagram I made to show you how simple the wiring is.
bobbyd
312
San Antonio/Los Angeles
Jun 23, 2005
  • Jun 23, 2005
theres are a diagram in the 5.0 talk section let me get the link
dkins419
187
Michigan
Jun 23, 2005
  • Jun 23, 2005
What kind of wire do you use to extend your switch?
bobbyd
312
Jun 23, 2005
  • Jun 23, 2005
http://forums.stangnet.com/showthread.php?t=556401
Blakthorn
299
US
Jun 23, 2005
  • Jun 23, 2005
Where can I find the wire to splice, what color should it be, and what type of wire must I buy from radio shack to attatch to the wire i cut and to the switch ?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2005
  • Jun 23, 2005
On 86- 91 cars the fuel pump relay is under the seat, 92 and later cars, the fuel pump relay is under the Mass air duct on the passenger fender well.
Note that the wire colors changed in 1991, so there are two different descriptions.
86-90 model cars:
Cut the red/black wire going to the fuel pump relay. Splice a 16 or 18 gauge wire into the wire and connect it to one side of the switch. Connect the other side of the switch to the other end of the red/black wire going to the fuel pump relay. When you are done the switch should be in the middle of the spliced red/black wire that goes to and comes from the fuel pump relay. Using the control side of the circuit allows you to use light gauge wire and light duty switches. There is less than 1 amp going through the circuit, so you don’t have to worry about voltage drop across the wiring depriving the fuel pump of electrical power.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model wiring diagrams.
91-93 model cars:
Cut the Lt Blue/Orange wire going to the fuel pump relay. Splice a 16 or 18 gauge wire into the wire and connect it to one side of the switch. Connect the other side of the switch to the other end of the Lt Blue/Orange wire going to the fuel pump relay. When you are done the switch should be in the middle of the spliced Lt Blue/Orange wire that goes to and comes from the fuel pump relay. Using the control side of the circuit allows you to use light gauge wire and light duty switches. There is less than 1 amp going through the circuit, so you don’t have to worry about voltage drop across the wiring depriving the fuel pump of electrical power.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model wiring diagrams.
Blakthorn
299
US
Jun 23, 2005
  • Jun 23, 2005
perfect, thanks
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
