Fuel Filter Location
Another thing to note is that on newer Ford's there isn't a shreader valve to bleed the pressure. If you don't have one, the procedure is to run the car with the fuel pump relay out until it dies.
Not good for the engine, but it's the only way to do it.
I have had good luck just letting the car sit overnight and changing the filter the following morning. Fuel pressure can take quite some time to bleed off. I can't say it will work for everyone but, it has worked for me.
