  • SN95 4.6L Mustang Tech
Fuel Filter Question
  • Thread starter Thread starter IJUSTWON
  • Start date Start date May 5, 2005
I
IJUSTWON
242
  • May 5, 2005
What is a good replacement Fuel Filter for my 2001 Mustang Bullitt? And Where can i get a replacement?
R
rjstaaf
1,310
Somewhere
May 5, 2005
  • May 5, 2005
I would stick with the Ford Motorcraft replacement but, that is just me.
stripped302
84
Shelby Twp, MI
May 5, 2005
  • May 5, 2005
I just finished mine,went with motorcraft.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 5, 2005
  • May 5, 2005
Motorcraft... You will need a spring lock release tool and you will need to depressurize the fuel system first.
www.bullittarchive.com
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 5, 2005
  • May 5, 2005
you can depresure the system by pushing in the schrader valve on the fuel rail. or you can wait awile after you shut the car off then do it without depresurizing
MT1083
1,033
Charlotte, NC
May 5, 2005
  • May 5, 2005
I just pulled the fuel pump fuse while the engine was running to release any pressure.
Mike97gt
it doe snot
10,633
May 5, 2005
  • May 5, 2005
you guys can do that.. but i have never released the fuel presure on any fuel filter i have done.. and as long as it was shut off for 15 minutes or so it was fine.
if you pull the line right after you shut it off you will get sprayed. no matter what you do some fuel will come out
ts1lmayb
67
Alabama
May 5, 2005
  • May 5, 2005
gas will just shoot out of the line once you remove it. no biggie, just be ready for it.
I
IJUSTWON
242
  • May 5, 2005
Where can i get this replacement? And how much should i expect to pay?
merc123
420
North GA
May 5, 2005
#10
  • May 5, 2005
  • #10
Wal-Mart has it. I think you can get them for less than $12 at about any parts store.
pdl2flr
154
Leesburg, VA
May 5, 2005
#11
  • May 5, 2005
  • #11
I just installed a Purolator filter on my GT that I picked up at AutoZone (Motorcraft was out of stock). I also picked up the spring release tool while I was there which made the install a breeze. I pulled the fuel pump fuse and ran the car for a few minutes, not till it stalled but just to relieve the pressure. Only had a few ounces of fuel spill out.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 5, 2005
#12
  • May 5, 2005
  • #12
what i do is open the trunk with the car running and give the kill switch sensor a good whack with a ratchet. after about 10 seconds the car dies on its own. that generally releives all the pressure becasue the kill switch turns off the fuel pump in case of an accident. once i change the filter, i push the button back in and the car starts fine.
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
A
87 GT - Low Fuel Pressure Problem
  • Asbury
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
