  • SN95 4.6L Mustang Tech
fuel Filter question
  • Thread starter Thread starter mity2
  • Start date Start date Jul 12, 2005
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jul 12, 2005
  • Jul 12, 2005
I'm thinking about changing Fuel filter this comming weekend.
i'm getting special tool to remove clip and such, but got thinking.
How do u releave the fuel pressure? should I start car with fuel pump fuse out and let it die?
stangman
2,690
10
69
in a 3 bed, 2 bath
Jul 13, 2005
  • Jul 13, 2005
meh, just put some paper towles down & just take it off. some gas comes out but not that much
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Jul 13, 2005
  • Jul 13, 2005
or if you really want to know how just for ****s n giggles, heres a link on how to
http://www.bullittarchive.com/html/modules/articles/article.php?id=73
mity2
Jul 24, 2003
2,872
StateCollege PA
Jul 13, 2005
  • Jul 13, 2005
cool thanks!
StangPro
441
Roseville, MI
Jul 13, 2005
  • Jul 13, 2005
If you have a schrader valve, use it. If not, pull the fuse and let it die. The newer cars don't hav valves and have to do it that way.
02_TruBlu
54
Pittsburgh
Jul 13, 2005
  • Jul 13, 2005
Just did mine this past weekend and followed the instructions from the bullitarchive link. I just pulled the line without relieving pressure and enough gas ran down my arm for me to put the line back on and then use the shrader valve. I spent more time putting the car on ramps then I did anything else, the job is quick and simple.
mity2
Jul 24, 2003
2,872
StateCollege PA
Jul 13, 2005
  • Jul 13, 2005
cool. thats what i'll do. i figured its easy enough menitenace to do that is overdue
R
rjstaaf
1,310
Somewhere
Jul 13, 2005
  • Jul 13, 2005
The easiest method to relieve the pressue is to just let the car sit overnight and change the filter in the morning. The pressure will bleed off overnight. This is how I do it and have never had an issue.
propellerhead
1,541
"but what's with the but shots?"
Jul 13, 2005
  • Jul 13, 2005
Yup. Much easier. I do this on my Mustang and my Ranger.
G
gfhoward
18
#10
  • Jul 25, 2005
  • #10
Hmmm, I was having a hard time getting the hoses off of my 2000 GT when I came upon this thread. The spring release tool did the trick, but I don't think 2000 GT's are supposed to have hard lines going to the filter with spring release mechanisms like mine has. The link would seem to indicate that they are normal on a Bullitt, but my manual and another tech I spoke with both indicate that this set-up should not exist on a 2000 GT. Can anyone solve the mystery? Thanks, G
R
rjstaaf
1,310
Somewhere
Jul 25, 2005
#11
  • Jul 25, 2005
  • #11
My 2001 was built in October of 2000 and it has the spring release type safety connections. Here is an image from www.alldata.com on the 2000 GT fuel filter, looks like it shows them.
G
gfhoward
18
#12
  • Jul 25, 2005
  • #12
I don't see how that diagram has anything to do with a fuel filter but thanks for the response. So did Ford switch to hard lines and spring locks in late 2000? It would seem odd for them to switch midway through the line rather than just making the switch for the 2001 line. Do the 2001 GT's all have these features then? Maybe I have a 2000 GT built late in the year and it received the upgrade early. The 2000 repair manual I have doesn't indicate the possibilty of these features. Any more input from anyone?
R
rjstaaf
1,310
Somewhere
Jul 26, 2005
#13
  • Jul 26, 2005
  • #13
I directly linked to the image on Alldata, looks like that didn't work. It should be fixed now.
What repair manual do you have?
W
Will Smith
191
Cape Coral, FL
Jul 26, 2005
#14
  • Jul 26, 2005
  • #14
u don't need a special tool for one. just use a flat head screw driver. and two, I wouldn't worry bout bleeding the system off. just pup the locks off with the screw driver and go. should take 5-10 min max.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 26, 2005
#15
  • Jul 26, 2005
  • #15
No, use a spring lock removal tool and do it properly... The spring lock release tool is VERY cheap so why not get one and use it? Flathead screwdriver...
BigNutt
43
Birmingham, Alabama
Jul 26, 2005
#16
  • Jul 26, 2005
  • #16
Where do you get these "special tools" from?
R
rjstaaf
1,310
Somewhere
Jul 26, 2005
#17
  • Jul 26, 2005
  • #17
Here is a good set from Sears for $9.99 that will work on both AC and Fuel lines. You can get a much cheaper set at just about any auto parts store that will work just as well.
http://www.sears.com/sr/javasr/prod...ecegjdghldfoo.0&pid=00946337000&vertical=TOOL
mity2
Jul 24, 2003
2,872
StateCollege PA
Jul 26, 2005
#18
  • Jul 26, 2005
  • #18
ya don't ness with screw driver. I mean its FUEL LINE!!! don't take chance
BTW, i haven't done this yet. haven't had time...
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
