twogts4us said:If I may, I'll add 2 cents to the Bullitt Archive article - I found it is useless to try to release the fuel pressure via the schrader valve. Face it, changing the fuel filter will be a bit messy...but be careful...fuel in the eye or other sensitive areas (I had some run down my arm to my armpit -ouch!) is quite painful. Other than that, this is an easy, slamdunk job. Just be sure to have the correct disconnect tool - the simple plastic ones are the best, IMO.
sgarlic said:Metal tool sucks, and so do the 'simple plastic' ones. We broke BOTH sets a couple weekends ago replacing a fuel pump on a Bronco. It's very hard to get leverage in tight places with the metal ones, and it's hard to get leverage at ALL with the simple plastic ones.
The ones with the spring are by far the best.. that are shaped like an O with a hinge.
