My fuel gauge isn't working on my 91 GT. It was like this when I got it. I have been trying to find out why it's not working. I checked the two wires by the fuel tank that run to the sending unit. When I touch the wires with the engine running, I get no voltage. From what I've read I should have 12 volts. I am getting zero.
Also these two wires should NOT be connected, right? The reason I ask is because when I use my meter to check for continuity between the black and yellow wire I get the steady beep sound to show those two wires are connected somewhere.
Does this mean these two wires are shorted or does it mean the anti-slosh module is bad?
I read a post by Jrichker on this forum from the past that said not to short the black and yellow wire together to peg the gauge because it could fry the voltage regulator. Well if these two wires have continuity between them, does that mean it is already fried?
