Fuel Injector Question
  • Thread starter Thread starter craigwhite89gt
  • Start date Start date Mar 14, 2006
craigwhite89gt
181
Cecil County Maryland
Mar 14, 2006
  • Mar 14, 2006
Ok ive been having this problem where im getting a light white smoke from my tail pipes --- NO ITS NOT A HEADGASKET!!! --- And the car runs like crap and pops at low rpms, It smells like RAW FUEL, so i pulled out the plugs and my number 7 plug smells like gas and is a little wet while all the others are fine. So i got a looking around and noticed my intake manifold (trickflow) was smashed down on the injector, and the wires on the harness are not in the best shape a little fraile. So if the wires were kinked badly and or touching eachother is it a good chance that the injector is sticking open flooding that cyl.????
76
  • Mar 14, 2006
What you are describing sounds like a definite possibility. My question is why is the intake hitting the injector? You may need to rotate the injector a little for clearance. The injectors are constantly supplied with 12V (run and start position) and the ecu grounds the return wire to fire the injector. It sounds like the return wire is grounding itself (shorting) holding the injector open. Excess/unburned fuel would be white smoke. Don't forget to change the oil once you've fixed the problem.
craigwhite89gt
181
Mar 14, 2006
  • Mar 14, 2006
Yea when i put the manifold on i didnt think to look onder and see if it had clearance, and to rotate it. Im hoping this will solve my problem.
craigwhite89gt
181
Mar 15, 2006
  • Mar 15, 2006
anyone know of any place that sells the Fuel injector harness?
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
