  • SN95 4.6L Mustang Tech
Fuel Issues?? - Need Help
  • Thread starter Thread starter Steedaq
  • Start date Start date May 2, 2007
Steedaq
20+ Year Stangneter
Dec 16, 2003
88
9
18
May 2, 2007
  • May 2, 2007
Hi all,
I've got a 2001 GT with dual pumps and am having problems. Here's the deal:
1. I've currently have about 2 psi at the rail.
2. The fuel pumps are good.
3. The fuel pump driver module is good.
4. The sensor that's mounted on the fuel rail is working.
5. The 20 amp fuse has not blown.
The dealerships I've talked to have been of very little help. The car ran well on the way down to MPH to get it dyno tuned. The car ran great on the way back for 100 miles, and I lost all of my fuel pressure.
I'm currently at a loss...Does anybody have any suggestions?
Thanks.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
May 2, 2007
  • May 2, 2007
let's start with the obvious question. did you check for leaks?
have you logged the fuel pump duty cycle?
are you sure nothing came loose in the tank?
has the fuel filter been changed recently?
hope those help.
Steedaq
20+ Year Stangneter
Dec 16, 2003
88
9
18
May 2, 2007
  • May 2, 2007
Ok, I've got answers for those questions.
1. No leaks
2. Tim logged the fuel pump duty cycle at MPH. The pumps are new Bosch pumps used in the 03-04 Cobra.
3. Fuel pumps/hoses did not come loose.
4. I just changed the fuel filter this afternoon.
Keep 'em coming
Steedaq
20+ Year Stangneter
Dec 16, 2003
88
9
18
May 3, 2007
  • May 3, 2007
Is it possible that the inertia switch went bad? It didn't need to be reset, but I'm starting to run out of ideas.
C
chuck943
262
north carolina
May 3, 2007
  • May 3, 2007
only other thing left is CCRM,possible relay is sticking. If you could get it acting up again check pin 5 dg/ye wire,it is the feed to inertia switch.
Steedaq
20+ Year Stangneter
Dec 16, 2003
88
9
18
May 4, 2007
  • May 4, 2007
Thanks!! I'll check it out.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
