I want to replace my fuel line, where can I get new ones?
Can I use the braided lines with that connect to each fuel log separately,if so where does the reg go? thanks in advance for any helps
WHY? What are you running or planning on running? Stock fuel lines should be good to 400 HP or so. Check out Summit Racing http://store.summitracing.com/motorsports/index.htm for help, although you really need the paper catalog to find what you want.
You can purchase fuel rail adapters that will connect to your quick disconnects on your rail. The summit part numbers are rus-640870 and rus-640880. Then you can run -6 and -8 braided line back. Hope this helps.
