Fuel Press. Settings
  • Thread starter Thread starter ninety15.0
  • Start date Start date May 13, 2004
ninety15.0
1,336
  • May 13, 2004
Hey so i finally go my fuel pressure guage situation figured out,and now i need to test it. I think that the fuel press is supposed to be around 36-38psi with the vac off right? now what exactly does that mean? do i pull the vac line out of the regulator or is it another vac line? i dont have a AFPR, mods in sig, and any help or info on the best way to test this would be awesome! thanks
-nick
88stangmangt
2,332
Stafford,VA
May 13, 2004
  • May 13, 2004
stock is 35-40 i believe.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 13, 2004
  • May 13, 2004
Yup, the vac off means the vaccume line to the regulator is removed. I have mine set to about 37 psi. However, the AFPR is a tuning tool, so maby you should experement with different settings.
ninety15.0
1,336
  • May 13, 2004
Awesome thats what i thought....now when i test it there isnt going to be a load on the engine, so if the pressure is any lower than 35ish then i might have some problems. Also how would i test it with a load on the engine? the guage is under the hood which makes it a PITA to look at it while driving! haha. thanks for the help guys!
ninety15.0
1,336
  • May 13, 2004
Anyone?
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
