fuel pressure gauge on bbk fuel rails
ll2none
i just put the bbk fuel rails on my motor, i want to put a fuel gauge on. but i dont see how to do it. the rails dont have a place to put the fitting for the gauge like the stock rails had.. any suggestions...
did you use an aftermarket FP reg.? if so it might have a port, like my aeromotive does. if not, check the steel fuel lines that connect to the fuel rails, the inlet line should have a port as well.
steel lines
the fuel pressure gauge connection port(also known as the shrader valve)is not located on the fuel rails at all,its on your metal fuel lines.go back about 5 or 6 inches from the disconnect fittings on your fuel lines and youll find the fitting.it might have a metal or plastic cap(kinda like an ac refrigerant fittng)screwed on top of it.passenger side near maf meter.thats your connection port
