Fuel Pressure Gauge?
Guero said:
i have to remove it how?
just get an open-end and turn it, but make sure the pressure is out of the lines and when you go to tighten the new gauge in make sure you dont over tighten, it doesnt have to be ball busting tight. Don't forget the telfon tape for sealing :nice:
first you have to make sure your gauge comes with the adaptor(not sure on size) so it can replace the valve. I think they make the guage were you can jsut screw it on the existing valve also.
think that covers it.
yes, look at the passenger side fuel rail. at a spot very close to the front of the car you will see the valve. unscrew the little black cap and push down on the valve (similar to the valve on the tire) to let the fuel pressure out (gas will come out). then it takes like an 8 or 9 mm wrench to take the valve off of the rail.
SM0k3 said:
:rlaugh: :rlaugh: yep big time!!
one of my old friends(Old as in age) said he use to have a compresser to air up his tires form the engine it self. so i was looking to see if it was true and saw the valve and bam it hit me lol
