fuel pressure o when hot
brian88
18
88 gt 302 edelbrock carb,brand new holley blue all new an lines, new regulator, filters ,all new painless relay kit to pump. Started up runs good 6lbs pressure, drive it till it gets warm fuel pressure drops to 0, but it still runs like a raped ape, but pressure regulator wont`bring it up???????? I have a gauge on it right next to the carb. Like I said it runs fine even when the gauge is at 0 and the a/f gauge is still reading fine? ANYBODY HAVE ANY IDEAS?????? We did put roller rockers on it but they were adjusted to ford racing specs, and rev to 7000 without problem. Let it set and cool off for 20 min or so pressure comes back. Everything is new ,less than 50 miles on it and was doing it with the old setup to. HELP??? CARB??????
that is what i was thinking,it is still the old gauge. I just went out and hit the key on ,motor is cold and it was at 6 pounds steady. it will stay there untill you go up the road and it get to operating temp then 0. it did this before when I was runing the in tank pump regulated down to 6,but I had a walbro 255 in it and knew it was a time bomb but that is the way it was when I bought it, but it still did the same thing then, would start out at 6 and then go to 0 and it did not matter where you adjusted the regulator at.That is why I went to all new , with holley blue, lines ,regulator but I did not change the pressure gauge. even before it ran just fine but the gauge said 0.
Let me guess here
Is the gauge liquid filled ? If so that for sure your problem get a non-liquid filled gauge
When the liquid warms it expands and will give false readings
my bbk did that
I guess I`m outta ideas . do you think the heat could be killing it? it is a summit cheap gauge that is on it. I do not know what else it could be? like i said we turned 7,000 rpm tonight with it at 0 and it didn`t miss a lick at 120 mph. I was mad so I figured it would go or blow!!! it ran great gauge just said 0. it is liquid filled if that makes a difference. A little more info on the car
88 gt
comp cam 5.50 in 5.75 ex. lift 114 lobe seperation
.030 forged pistons,h beam rods
wieand stealth intake,gasket ported
e7 heads fully ported,polished,stainless swirl valves
comp 986 springs
ford racing roller rockers
ford racing pushrods (longer roller rocker versions)
msd everything
bbk long tubes,bbk x pipe
flowmaster exaust
customs brackets for alt and power steering
tremec 5 speed built by tko performance
alot of other stuff , it is all new except for the carb which is about 3 monts old.
how should I hook it up? I have it in line spliced into the fuel line between the regulator and carb. Should I run it off of the port on the regulator that I plugged?
Wow, I've had the same problem with my interior mounted liquid filled fuel pressure gauge too but only if driven on a very hot day. Took about 15 minutes of driving before it went to zero.
I've got the Holley Black pump, large fuel line (10) and up 'til now thought that I had some weird fuel related problem, like improper tank venting (or pump sucking air) when hot or something.
I usually don't drive the 'stang when it's that hot out now (prefer AC cars then) so I havent experienced that in years but I remember being pretty freaked out seeing 0 pressure before getting onto the freeway, thinking I'd need a tow. It also never skipped a beat so obviously it was getting fuel pressure too.
Keep us informed 'cause if the guage cures it, I'll get a new guage as well.
Put new gauges on it, not liquid filled ones either just regular ones , one at the carb, one on the other side of the fuel pressure regulator, it was raining so no road test but let it set in garage and get around 190 degrees ., and it was fine even if I opened up the secondaries it was at 5psi at the carb and 8 at the regulator. Can`t wait till the rain stops, slicks do not like rain!!!!!
