Fuel Pressure Question
89_FakeSnake
93
Sacramento, CA
After engine cut off - how long is pressure in the system supposed to remain? Is it normal for pressure to drop within minutes after the engine is stopped?
Also does anyone know of some effective ways to test a stock pressure regulator(fox)? Thanks in advance all. :nice:
All aftermarkets FPR will drop near immediately, I have had some stockers hold pressure for a little while after the system is shut off.
The FPR is in the retuirn line so it is only holding pressure back when fuel is being fed against it.
I am assuming you have a guage, this is the most effective way to see what is going on with your fuel pressure. Most of the timw when the diagphram faisl you will get gas in the vac line that attaches to it.
If youre using the fuel rail with a gauge trying to check fuel pressure, after you shut down the motor the fuel pressure is supposed to stay up for a while. If youre pressure is dropping off after you shut off the key then you have something wrong. Im having the same problem. Im pretty sure one of my injectors is leaking. Alot of times the fuel pump will bleed off pressure if its time for a new one.
