Fuel Pressure Rec's???
cjhenry01
43
Where should I set my Fuel Pressure? Please see my mod's.
Currently with the car running at idle & with the vaccum connected mine is reading 35-36.
Also, How exactly do I set it? I know I should disconnect the vaccum, but do I disconnect it with the car running or not running?
Disconnect the vacuum with the engine running, and read your gauge and set the pressure.
If you have read other similar posts like this one then you will know that asking where to set the pressure is like asking what you should set your timing at.
I'd start with 38-40psi with the vacuum off and go from there and see what makes the most power.
Get one of your buddies to ride along with you. Find a level stretch of road where you can do some testing. Don't choose a speed range that will make you shift gears, the shift quality & speed will affect your results. Use 2nd or 3rd gear and do a run from 2000 RPM to 5800 RPM. Call out the RPM as it increases and have you buddy record it and the elapsed time. If you have one of those cheap digital watches like I do, a stop watch is built in. Start the fuel pressure at 36 PSI, vacuum off and make a run. Turn it up to 37 and make another. Be sure to reconnect the vacuum every time you set the pressure. Keep turning up the pressure and making runs until you notice a drop off in time. If your bud was careful to record the results, you'll have a nice chart to use to find the optimum pressure.
Pull the vacuum line off the regulator and plug it.Its right behind the throttle body on the fuel rail.If you have the stock regulator there is no way to adjust it.You need a adjustable one.
sublime29 said:
When you unplug it you will create a huge vacuum leak!!
Not a huge leak since the line is so small, but it may upset the idle a little. I don't worry about it, since the power brakes and PVC pull more vacuum than the loose vacuum line for the fuel pressure regulator.
