Fuel Pressure Regulator And Running Lean
  • Thread starter Thread starter dz01
  • Start date Start date Apr 28, 2015
1 of 2 Next Last
dz01
285
10
Massachusetts
Apr 28, 2015
  • Apr 28, 2015
Any issues with unplugging the fuel pressure regulator vacuum line and capping it temporarily for a couple test runs? I'm pulling a Code 41 and 91 which are lean O2s. I have a feeling my fuel pump is operating right on the line of decent, but not great. I've heard others pull the vacuum line and get more PSI fixing the lean O2 issue (at least temporarily). I'm trying to pinpoint a fuel problem vs. a vacuum leak problem. Some of the previous threads I've read on the topic don't really provide very much detail so I apologize if I misunderstood.
My car also chokes at lights sometimes leading me to also believe I have a fuel problem.
My FPR looks new and I recently replaced my fuel filter.
I'm also planning to check my fuel pressure again.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 29, 2015
  • Apr 29, 2015
Stock car?
dz01
285
10
Massachusetts
Apr 29, 2015
  • Apr 29, 2015
Some mods- exhaust, headers, 65mm Tb, intake
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 1, 2015
  • May 1, 2015
You have probably seen this before, but have you actually tested the O2 sensors and wiring as described in the tech note below?
Code 41 or 91. Or 43 Three digit code 172 or 176 - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
Revised 6-Oct-2014 to improve code 41 description due to clogged Thermactor air crossover tube
Code 41 is a RH side sensor, as viewed from the driver's seat.
Code 91 is the LH side sensor, as viewed from the driver's seat.
Code 172 is the RH side sensor, as viewed from the driver's seat.
Code 176 is the LH side sensor, as viewed from the driver's seat.
Code 43 is not side specific according to the Probst Ford Fuel injection book.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors 87-93 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear.
Disconnect the O2 sensor from the harness and use the body side O2 sensor harness as the starting point for testing. Do not measure the resistance of the O2 sensor , you may damage it. Resistance measurements for the O2 sensor harness are made with one meter lead on the O2 sensor harness and the other meter lead on the computer wire or pin for the O2 sensor.
Backside view of the computer wiring connector:
87-90 5.0 Mustangs:
Computer pin 43 Dark blue/Lt green – LH O2 sensor
Computer pin 29 Dark Green/Pink – RH O2 sensor
The computer pins are 29 (L\RH O2 with a dark green/pink wire) and 43 (LH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
Computer pin 43 Red/Black – LH O2 sensor
Computer pin 29 Gray/Lt blue – RH O2 sensor
The computer pins are 29 (LH O2 with a Gray/Lt blue wire) and 43 (RH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer. Using the Low Ohms range (usually 200 Ohms) you should see less than 1.5 Ohms.
87-90 5.0 Mustangs:
Disconnect the connector from the O2 sensor and measure the resistance:
From the Dark blue/Lt green wire in the LH O2 sensor harness and the Dark blue/Lt green wire on the computer pin 43
From the Dark Green/Pink wire on the RH Os sensor harness and the Dark Green/Pink wire on the computer pin 29
91-93 5.0 Mustangs:
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 43
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 29
94-95 5.0 Mustangs:
Computer pin 29 Red/Black – LH O2 sensor
Computer pin 27 Gray/Lt blue – RH O2 sensor
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 29
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 27
There is a connector between the body harness and the O2 sensor harness. Make sure the connectors are mated together, the contacts and wiring are not damaged and the contacts are clean and not coated with oil.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness.
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
Code 41 can also be due to carbon plugging the driver’s side Thermactor air crossover tube on the back of the engine. The tube fills up with carbon and does not pass air to the driver’s side head ports. This puts an excess amount of air in the passenger side exhaust and can set the code 41. Remove the tube and clean it out so that both sides get good airflow: this may be more difficult than it sounds. You need something like a mini rotor-rooter to do the job because of the curves in the tube. Something like the outer spiral jacket of a flexible push-pull cable may be the thing that does the trick.
If you get only code 41 and have changed the sensor, look for vacuum leaks. This is especially true if you are having idle problems. The small plastic tubing is very brittle after many years of the heating it receives. Replace the tubing and check the PVC and the hoses connected to it.
dz01
285
10
Massachusetts
May 1, 2015
  • May 1, 2015
Ok, so here are my results after checking my fuel pressure again last night:
- Engine off, car stone cold, key on to kick in the fuel pump = 30 (after 10 mins dropped to 26). Also make note the pressure didn't jump immediately up to 30 with the key on, it gradually climbed to 30 (2-3 seconds)
- Engine on = 34
- Engine on, pulled vac line on FPR = 42
- Engine on, steady rev to around 2,000 rpm = 32
- Engine on, short burst revs = 40
- Shut car off = 38, but climbed to 40 after a minute. 10 mins later still had a solid 40
My FPR has been replaced, but I think I'm running the original pump. Pump weak with key on? Definitely bleed down noticed right away when car was cold. Odd I didn't have the same bleed down with the car warm (15 mins of running).
Thoughts?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 1, 2015
  • May 1, 2015
The drop off after the engine shutdown is not a concern unless you are having problems starting the car. There is a check valve in the pump that holds pressure after the pump power is turned off. The fuel pressure regulator can cause the same symptoms.
The only 2 things you need to worry about is the pressure with the engine running and the vacuum connected: is less than 37-41 PSI?
When you disconnect the vacuum with the engine running at idle, does it increase to the 37-41 PSI range?
How the fuel pressure regulator works
Revised 29-Aug-2013 to make the pressure/vacuum relationship clearer,
The fuel pressure regulator in 5.0 Mustangs is a shunt regulator that works in parallel with the fuel injection system. The regulator bypasses fuel back to the tank to maintain a constant 39 PSI to the injector tips. A constant pressure insures that the computer will always have the same flow rate to base its calculations on.
The 39 PSI pressure is measured at 29.92 inches of atmospheric pressure to get the proper injector flow rate. But the pressure inside the intake manifold may be higher or lower than the atmospheric pressure outside the intake manifold. These differences would cause the flow rate to change and mess up the computer’s air/fuel calculations.
As the vacuum inside the intake manifold increases, the effective pressure at the injector tips increases. Conversely, as vacuum inside the manifold decreases, the effective pressure at the injector tip decreases.
Some math to illustrate the effect:
39 PSI at 20” of vacuum inside the manifold works out to be 49 PSI,
since the 20 “ vacuum/2 = 10 PSI that you add to the base fuel pressure.
That gives you 49 PSI at the injector tip.
39 PSI at 5” of vacuum inside the manifold works out to be 41.5 PSI,
Since 5” vacuum/2 = 2.5 PSI that you add to the base fuel pressure
That gives you 41.5 PSI at the injector tip
39 PSI with 10 lbs of boost inside the manifold works out to be 29 PSI.
That gives you 29 PSI at the injector tip
That reduces the flow rate and explains the need for higher pressures on engines with pressurized induction.
Since intake manifold vacuum and pressure plays havoc with the pressure at the injector tips, what has to be done to get it back in the magic 39 PSI range? That’s where vacuum applied to the back side of the fuel pressure regulator comes in. Remember this: unless you have some really poorly designed or trick plumbing, vacuum is the same throughout the engine’s vacuum system.
Apply 20” of vacuum to the back of the regulator and the 49 PSI pump pressure with 20” of vacuum at the injector tips drops to 39 PSI.
Apply 5” of vacuum to the back of the regulator and the 41.5 PSI pump pressure with 5” of vacuum at the injector tips drops to 39 PSI.
Here’s another side effect: apply 10 PSI boost pressure to he back of the regulator and the normal 39 PSI at the injector tips increases to 49 PSI. That overcomes the 10 PSI in the intake manifold to give you 39 PSI at the injector tips. Pretty clever of these engineers to use intake manifold vacuum and pressure that way.
Simply stated, intake manifold vacuum adds to the effective fuel pressure at the injector tips. Apply the same vacuum to the back side of the fuel pressure regulator, and everything balances out. Add pressure to the intake manifold and the effective fuel pressure at the injector tip decreases. Apply the same pressure to the back side of the fuel pressure regulator, and everything balances out.
Now you know why to disconnect the vacuum when making fuel pressure measurements.
dz01
285
10
Massachusetts
May 1, 2015
  • May 1, 2015
Thanks. So of the two things to worry about, both are not as described-
Car on vacuum connected i'm below 37-41 psi. I'm at 34
Car on vacuum disconnected I'm above 37-41. Im at 42.
So need a new pump?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 1, 2015
  • May 1, 2015
If you needed a new pump, most likely you would not hear it come on when you turn on the key and the FP would be very erratic.
Do you smell gas in the FPR vacuum line? My vote is replace the FPR
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
May 1, 2015
  • May 1, 2015
@madmike1157 - can you merge his posts? he has like 3 on the same subject of his FPR.
dz01
285
10
Massachusetts
May 1, 2015
#10
  • May 1, 2015
  • #10
I did smell a little gas in the FPR line. I'm assuming it's not possible to replace that thing without the upper intake removed?
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
May 1, 2015
#11
  • May 1, 2015
  • #11
It's possible with the intake on but you need tiny hands, a mirror and will be installing the hex bolts from the bottom up in a confined area. Either remove the throttle body and EGR or it's 6 bolts and move the upper out of the way..
dz01
285
10
Massachusetts
May 1, 2015
#12
  • May 1, 2015
  • #12
I just took a closer look, upper definitely needs to come off first.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 1, 2015
#13
  • May 1, 2015
  • #13
What? no midgets in your toolkit? No tiny hands to reach in and turn screws in impossible places?
That's something every Mustang hobbyist needs. Just wait until you try to change the EEC computer power relay...
Reactions: dz01 and mikestang63
dz01
285
10
Massachusetts
May 2, 2015
#14
  • May 2, 2015
  • #14
I need to replace my sending unit anyway. I'll probably end up doing the pump and FPR. I noticed a Motorcraft pump assembly is $$, but there are a lot of aftermarket brands. Any recommendations for a mostly stock set up? Don't want to spend $400, but want something that is known for decent reliability. Delphi has a whole hangar pump assembly for $80. Summit sells a bunch too- Walbro pumps but would have to by a separate hangar and sending unit. Bosch sells for $70 but unclear if pump is included. Need to find out what stock Iph is I guess too if I get a pump separate.
Thanks
dz01
285
10
Massachusetts
May 2, 2015
#15
  • May 2, 2015
  • #15
Thanks! A few of them aren't my threads and they are pretty dated. No close out with them so I figured I'd try and ask. I always try and close out to be helpful for the person running down a similar problem.
dz01
285
10
Massachusetts
May 4, 2015
#16
  • May 4, 2015
  • #16
Cleared codes, pulled and plugged FPR vacuum line, let car warm up, and ran KOER. Pulled codes 41 and 91 again. Does this rule out needing to replace the FPR?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
May 5, 2015
#17
  • May 5, 2015
  • #17
Is the Smog system still functional? Some times part of that system can cause lean codes. It could be from constant air being injected into the exhaust, or leaking TAB and TAD solenoids.
dz01
285
10
Massachusetts
May 5, 2015
#18
  • May 5, 2015
  • #18
I do still have the smog system, but noticed one of the big hoses that I'm assuming used to go to the stock exhaust is pinched off. Normal? I ran two smoke tests, but may do another and look specially in the TAD/TAB area.
dz01
285
10
Massachusetts
May 6, 2015
#19
  • May 6, 2015
  • #19
Built a smoke machine last night. Time to test the vac system again. Will report back later this week.
dz01
285
10
Massachusetts
May 6, 2015
#20
  • May 6, 2015
  • #20
No vac leaks. Plug into brake booster hose and ran for 10 mins. Smoke came out of air intake, but no where else. Rule that out.
1 of 2 Next Last
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fuel Bad regulator diaphragm?
  • JD1964
  • May 20, 2025
Fox 5.0 Mustang Tech Jul 16, 2025
JD1964
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
