Fuel pressure regulator location...
  • Thread starter Thread starter 1991vert
  • Start date Start date May 2, 2007
1991vert
1,103
Ludlow, MA
May 2, 2007
  • May 2, 2007
...with aftermarket rails. Where do you all have your aftermarket FPR located? i dunno where to mount mine i know you can't have it on the firewall
88mouse
630
Mooresville nc
May 2, 2007
  • May 2, 2007
most that i've seen are on the firewall or on the fenderwell.
D
Deleted member 87397
May 2, 2007
  • May 2, 2007
Why can't you have it on the firewall? I'd go with the fenderwell, but I dont' see why you couldn't do it on the firewall. but then again I definitely don't know everything.
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
May 2, 2007
  • May 2, 2007
Mine is on the firewall too.
1991vert
1,103
Ludlow, MA
May 3, 2007
  • May 3, 2007
i thought that is not track legal to have it on the firewall? same case with an FMU?
Turkey Sammich
Jul 12, 2006
154
May 3, 2007
  • May 3, 2007
Odd. I've never heard of that before. First time for everything I imagine. I would check with local performance shops and or the track and ask.
1991vert
1,103
Ludlow, MA
May 3, 2007
  • May 3, 2007
i thought i remember someone telling mike (sirsureshot) that his regulator would not be track legal because he had it mounted on the firewall. i could be wrong, but i'll ask around
I
irish
168
Florida
May 3, 2007
  • May 3, 2007
I use aftermakret rails and an aeromotive fpr, I mounted it right next to the gas cannister on the passenger front framerail.
1991vert
1,103
Ludlow, MA
May 3, 2007
  • May 3, 2007
that's kinda...far away i wonder if i could mount it on the engine somehow so i dont have lines all over
Blown83GT
35
South Jersey
May 3, 2007
#10
  • May 3, 2007
  • #10
On the passanger fender by strut tower.
1991vert
1,103
Ludlow, MA
May 3, 2007
#11
  • May 3, 2007
  • #11
cool, doesn't rub the powerpipe?
OonDeanisS
902
Danbury, CT
May 4, 2007
#12
  • May 4, 2007
  • #12
can i put it under the louvers behind the firewall?
smr
167
Nor*Cal (Vacaville)
May 4, 2007
#13
  • May 4, 2007
  • #13
no fuel regulator or distribution block within six inches of front of firewall..nhra general rules. If youa rent track worried then mount it on firewall. Mount it on fender well. dont go behind louvers in firewall as this would put it behind firewall and is def not track legal.
1991vert
1,103
Ludlow, MA
May 4, 2007
#14
  • May 4, 2007
  • #14
i found out it's 6" forward from the flywheel is legal
Blown83GT
35
South Jersey
May 4, 2007
#15
  • May 4, 2007
  • #15
It's about 3/4" away.
smr
167
Nor*Cal (Vacaville)
May 7, 2007
#16
  • May 7, 2007
  • #16
exactly...firewall and flywheel reference usually same point. but yeah 6" forward of flywheel/flexplate..
1991vert
1,103
Ludlow, MA
May 11, 2007
#17
  • May 11, 2007
  • #17
found a spot for the Y-Block
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Fuel Anyone know a part number for a 3/8" inlet/outlet efi quick connect fuel filter that would fit the stock foxbody location?
  • rednotch
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 8, 2025
rednotch
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
