fuel pressure regulator
  • Thread starter Thread starter schwbs5.0
  • Start date Start date Aug 15, 2004
schwbs5.0
41
  • Aug 15, 2004
hey do fuel pressure regulators add horse power.couple of my friends told me i should get one they add horse power but im not sure.unless it depends on your mods.i have the basic mods heads.cam full exhaust and all the other basic bolts ons..any help would be nice...
but if so how would i adjust one?
PNY PWR
522
Wichita, KS
Aug 15, 2004
  • Aug 15, 2004
I'd like to ask if one might want one on a stock motor. Any advantages?
HISSIN50
34
129
Aug 15, 2004
  • Aug 15, 2004
i dont buy it. the puter can compensate for FP changes (up to 25 percent either way, then it tosses a code). with more pressure, you will shorten the duty cycle of the injectors. once the puter trims the fuel back (it is pretty adaptive and will learn how to compensate for what you did), the result is not great (only if you were outrunning your injectors, requiring say a 110% duty cycle to maintain the a/f ratio with stock pressure. bump pressure up so you can run at like 95-100% duty cycle).
im not really sure about WOT. some say the higher pressure will help at WOT (o2's not used), but others have said that the puter can even trim FP from WOT runs - i would leave that one up to the puter experts. if it does trim the FP at WOT, i am not sure why one would really need to bump the pressure on a stock-ish motor.
my two cents worth.
schwbs5.0
41
  • Aug 15, 2004
okay thanks again
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Aug 15, 2004
  • Aug 15, 2004
the only reason i put on on my car is beacuse i have bigger plans for the car.... i figured that i'm gonna need one anyway, plus it was a good deal on it
bowtietrader
68
  • Aug 15, 2004
with bigger injectors,i know it helps because that stock reg on the fuel rail can only pump so much gas..but if you do decide to get one, make sure you have a gauge so you can watch the pressure..
good luck
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fuel pressure regulator differences
  • dan50
  • Mar 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 26, 2026
dan50
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
A
For Sale Kirban Fuel Pressure Regulator NEW
  • afjLX
  • May 14, 2025
  • Engine and Power Adder
Engine and Power Adder May 14, 2025
afjLX
A
